I needto get a schematic for my gateway motherboard. I need the pinout/signals for the 7 pin battery connector. Can you help me with this? MB part nbr is 3507054R
    Problem Solver:
  • 7 Answers
Wht is the mobo name
Posted on Jan 07, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
Which connectors are used for front panel, power on (red @white) and led ( blue @ white) please show a close-up view
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light to see the marks.
Regards.
Feb 22, 2010 | Gateway GT5428 PC Desktop
Need Motherboard Jumper/Socket Pinouts
Did you ever solve the connector pins? I did for a MB I purchased. Respond on this and I will post the solution.
Apr 14, 2009 | Computers & Internet
Need schematic diagram for gateway mb 3507054R
operating system(XP_servispack_2)i have use but my probalm
is suddenly restart and blue scren comes
{asus_m2n_vm dvi,4400proser,3gbram using)
Jan 06, 2009 | Gateway Computers & Internet
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
P/S replacement in Gateway 2000 model year Tower
Gateway may have a unique non standard pinout for its P/S. I would match up the colors in sequence on the new PS and see if the old harness had the 6 pin connector and graft them into the new harness. The colors are standard for voltage.
Feb 11, 2008 | Antec TruePower Trio 550 (TP3550) 550-Watt...
MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
Oct 29, 2007 | Matsonic 8328E (MS8328E) Motherboard
Matsonic MS8328E user manual
Here is the pin out for USB connector. 1 VCC 2 VCC 3 USB0 4 USB1 5 USB0+ 6 USB1+ 7 GND 8 GND 9 Key(no pin) 10 USBOC
Aug 10, 2007 | Matsonic 8328E (MS8328E) Motherboard
Computers & Internet Logo
568 people viewed this question
David Payne
David Payne
