Question about Canon XL1S Mini DV Digital Camcorder
Eating Tape when rewinding in vcr mode
When the camera is in vcr mode it shows eject tape. When I reload the tape and I try to rewind or forward tape it goes really fast and eats it.
  • 2 more comments
  • jstefano Dec 10, 2007
    on taping the camera said to remove the cassette and once on rewinding it said to remove the cassette. Each time the tape had been eaten and broken.
  • shermqua Jul 14, 2008
    I have the same problem with my canon xl1s, with barely any use. I babied it and it ate my tapes.
    Did that work for you?
  • andrewlanham Aug 22, 2008
    I am having the same problem.  Place tape in and shortly thereafter it says remove tape.  Also, if I am lucky and place the tape in it will not play the video in the viewfinder at all. Help!
  • Lenxa Warna
    Lenxa Warna Mar 03, 2012
    its so simple to do, open the mechanical part, and check the pendulum part, it stuck caused oil mix with the dust, just clean the mechanic.
  • 883 Answers
Look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
Posted on May 27, 2007
SOURCE:
Why does my Optimus Model 163 MovieCorder 8 show "tape" blinking continuously and I cannot record or rewind or fast forward the tape.
This sounds like a fault caused by a mode switch problem. The mode switch tells the electronic section what position the VCR mechanical section is in. The mode switch itself can go faulty, or it can be sent to the wrong position if the VCR mechanism is damaged. For example the mode switch might be in eject mode, when the mechanism is in play mode.
It's unlikely that a reset would cure the problem. But you could try powering down the video by pulling the plug and leaving for some time. Maybe even a day.
Mode switch replacement is only possible if you have either done this before or have the service manual. Since most mode switches are never ever set up in the eject mode position. The VCR mechanism will also need to be checked to make certain it hasn't been damaged before resetting or replacement of the mode switch.
Mar 20, 2015 | Televison & Video
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
How many motors are in the VCR section? example 1 motor for play, 1 motor for hi-speed rewind, 1 motor for hi-speed forward.
There are only 2 motors on the VCR sections.1 motor for the rewind backward and speed foward.1 motor for take in the VHS tape and eject the tape.The play button also used the same rewind backward and speed forward motor to push the film foward to the VCR play head head drums to play the tape.
Nov 24, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
GE VG4056 will not rewind
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
Apr 27, 2008 | GE VG4056 VHS VCR
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Canon XL1S Mini DV Digital Camcorder Logo
485 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
