Burner and pilot run then kick off
Burner will run for about five mins and then kick off pilot and burner.
  • Anonymous Jan 06, 2009
    I have one that ran just fine last year an up till yesterday it did the same thing i took the thermal couple out and raised it up past notch then fasten it back the flame now hits it and it stays lite i hope it will work for you till you can get a new thermal couple
    Novelist:
  • 189 Answers
If this is electronic ignition you have a dirty flame sensor.
If you have a standing pilot light you should remove, dismantle and clean the pilot assembley.
Makec sure you clean the small gas oriface located inside the pilot assembly.
When you put it back together I would install a thermocoupling. Can be purchased for about $10 -$14 at any hardware store.
Posted on Mar 08, 2009
Can light the pilot no problem but when the burner kicks on it blows out my pilot light it will run fine for a while than I'll hear my burner kick in and the pilot light goes out what to do?
Call a service engineer tomorrow morning. The thermocouple has a shade over the top to prevent the flame being blown out, yours is either fallen off or needs adjusting. Also the pilot jet might need cleaning or replacing. It MAY need a new thermocouple but it sounds as if it is doing its job.
Dec 11, 2016 | Heating & Cooling
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Starts fine runs just about two min then kicks off and excesive fumes
Would say burners and pilot all need cleaning , blocked jets .
Nov 12, 2012 | Dyna-Glo (PPH16-LP) Utility Heater
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Im calling for heat from the thermastat and control panel, the boiler light and and the fan is running, but no matter how many times i keep re trying the pilot and burner will not commence, is there...
I would check to make sure control on gas valve is in on position and pilot is lit if you have a standing pilot. If you have a spark or hot surface ignitor make sure they are trying to lit pilot. If you have standing pilot model and pilot lit is not on. Turn control on gas valve to off,wait five mins. then turn to pilot. Depress botton and try to light pilot. If it lights hold down for a couple of mins. then release.. If pilot stays lit turn control to on. If thermostat is calling for heat this should bring main burner on. If pilot does not stay lit then replace thermocouple. Hope this helps. Thanks
Nov 16, 2010 | Heating & Cooling
Pilot light goes out when burners kick on burnham
Get a toothbrush and clean the **** off the pilot, could be partially blocked. Change the safety thermocouple. Check the plenum for cracks. A cracked heat exchanger can cause this.
Nov 07, 2009 | Goodman GMS90703BXA Heater
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
180 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
