Question about Rival CZF630 Deep Fryer
Food sticks to basket
When I deep fry battered shrimp, it sticks to the wire basket when I try to remove it after cooking. It is very difficult to get off. I have the oil about 375 and I use a batter consisting of flour,water,salt,oil and egg. I really like the shrimp, so I hope that you can offer me some suggestions to correct this problem. Thank you. Bert Acker
  • Anonymous Mar 18, 2014
    all the food is sticking to the basket aND I HAVE TO SCRAPE IT OUT HELP?
  • 3 Answers
I have this problem to. i think the best way to fix it is to drop the basket in the oil with the lid open, then carefully drop the food directly into the oil, that should cause the batter on the bottom to firm up a bit before resting on the basket. hope that helps.
Posted on Nov 18, 2007
  • 883 Answers
Try using virgin olive oil...
Posted on May 27, 2007
How big of turkey will a Morrone TKF 300 A turkey fryer cook.
Turkey Fryer is deep enough to fry a 12 to 14 pound turkey and wide enough to be used as a seafood boiler. Heating element is made of stainless steel. It comes with aluminum bailing basket with adjustable quick drain system, control with safety shut-off and a built in digital control with thermostat and timer. Swing out drain valve for easy draining and clean up. CSA certified.
Deep enough to fry a 12 to 14 pound turkey and wide enough to use as a seafood boiler, the Cajun Injector's Electric Turkey Fryer provides home fried cooking without the mess and hassle of stove top or outdoor methods. Equipped with a 30Qt. aluminum bailing-basket, you can submerge and fry a whole turkey or any other foods you'd like to cook fully covered. When the food is finished cooking, simply lift the basket up with the hanger hook, and allow it to drain over the pan with the adjustable quick drain system. A swing-out drain valve to empties the used oil when its time for clean up and a built-in digital control with a thermostat and timer ensures that the food cooks exactly as you intended. The CSA certified fryer features a clear lid so that you can check on the food without risk of burning and is equipped with a stainless steel heating element for long lasting quality.
Oct 21, 2014 | Grilling
How can I keep food from sticking to the bottom of my fry baskets?
After coating the food in batter slowly dip it into the oil allowing the item to get coated generously before dropping to the bottom of the fry basket. After a few seconds it is helpful to then lightly shake the fry basket.
Jul 15, 2012 | Cecilware V091A 11 1/4" x 4" x 4" Fry...
I have a deep fryer. When I am doing french fries the oil foams up in the basket. I have to hold the basket handle while I am frying otherwise the oil will overflow out of the basket. Is there something...
check your hot oil level, it may be above the mark. also follow the maximum recommended batch loading. overloading fryers will result in oil spillage (overflow from tank) during cooking cycle.
Mar 30, 2011 | DeLonghi D24527DZ Deep Fryer
Our battered chicken and fish is sticking to the basket what do we do?
Hi there:- You mean the products you put into the deep fryer stick to the basket or sunk down to the bottom and stick to the bottom basket. It can be a number of reasons but the most important is the temperature of the oil, it should be 350 degree F or more to do the frying , any temperature below that will be call boiling not frying. Secondly the batter mix ( you should try out and make your own batter mix ) Hope this can help.
Sep 23, 2010 | Rival CZF725 Deep Fryer
All battered items stick to the fryer's net and
It is NOT hot enough when you FIRST drop them in, it should be hot enough so that they Float, immediately they are dropped in.
Feb 28, 2010 | Philips HD6153 Deep Fryer
Bravetti pro 4 litre deep fryer model f1400b. used 3 times and whenever i use batter with like fish, put it in the basket, everything sticks to the bottom of the basket like glue. no matter what i try it...
Hi, this one is a bit tricky: you have to drop the basket first, hold on to one end of the fish without burning your fingers, and give the batter a minute - the whole piece will start to float when the batter starts to cook. You need to flip it over with tongs to cook it completely.
Sep 04, 2009 | Bravetti Kitchen Appliances - Others
Battered fish sticks tobottom of basket
Laura,
If you are battering your fish yourself, all you need to do is slowly submerge the fish into the oil, in increments of 1/4, 1/2, 3/4, and then 100%. You can do this in less than 30 seconds, you're just giving the batter time to "set". Also, about 30 seconds after the entire fish is submerged in oil, give the basket a good shake. This should dislodge it from the bottom of the basket. Keep your eye on things as the fish is frying.
If it's pre-battered fish, then just drop it in, wait about 30-45 seconds and give the basket a good shake, as I said before.
Beth
Mar 30, 2009 | Bravetti Kitchen Appliances - Others
Do not know how to use
Oil darkens with use the oil food molecules burn when subjected to high prolonged heat.
When frying foods such as fish or chicken use the oil once.
Do not filter oil over to reuse. Storing the oil in the refrigerator may extend the life of the oil, this should not be done ever. This process of chilling the oil and then burning the oil to room temperature causes excessive splattering furing the heat up.
Storing the covered oil in a cool dark place, for up to three months. ( remember to check oil when you use for color, smell, or excessive foaming. Throw out if there is signs of all the above.
This unit has a warranty for one year from the day of purchase.
Cooking:
When starting let unit reheat 7-10 minutes. This will get the heat to desired temperature. Re4ady light will cycle on/off during frying as temperature fluctuates due to food load.
Types of foods cooking: temperatures and time of cooking
Chicken strips 375 F. 5-8 minutes
Chicken pieces, bone-in 375 F. 15-20 minutes
Fish, battered 340 F. 8-10 minutes
French fries, frozen 375F. 3-5 minutes
F375F. 3-5 minutes
Onion rings 375 F. 3-5 minutes
Shrimp, breaded 375 F. 2-5 minutes
When frying frozen food if iced rub off lose as this can make the temperature of oil cool down. Pre-cooked frozen food cooks faster and does not come out oily.
I cannot wait to start cooking in mine as I got it for a christmas gift. Great recipes in the owners manual:
Apples fritters yum yum,beer batter for fish or chicken, deep fried chicken , chicken Kiev, quick doughnut made from biscuits, add topping of ground cinnamon and suger.
Dec 13, 2008 | Rival CZF625 Deep Fryer
Don't know how to work euro-pro deep fryer
Place the oil tub in the housing, and put the control unit on the back of the housing with the heating element inside the oil tub. Put room temperature (not chilled) shortening and/or lard in the oil tub. (Solid fats make better french fries, IMO.) Put the unit where you aim to cook, on a clear expanse of counter, where no one will knock it off. You are about to make boiling oil, and the potential for injury is truly medieval. Attach the magnetic power cord to the back of the control unit, and position the unit with the front of the control unit, which is at the back of the oil tub, facing you. Plug it into the wall. The magnetic cord attachment is easily knocked off, which is a safety feature, so don't knock it. If it comes off, just put it back on and restart the unit. Push button at lower right of control unit that looks like a 0 and 1 superimposed on each other. This is the power button. Put the lid on the unit with the two slots on top of the lid facing towards the front of the unit where you are. These two slots are where the basket will sit, but you haven't used the basket yet. Adjust the temperture using the + and- buttons. 375 is good for french fries. Now wait until the red light goes out and the green light (I believe) stays on. Now it's up to temperature and you can cook. Put frozen or washed and patted-dry (with a towel) french fried potatoes or battered fish or whatever you want to cook in the wire basket. Quickly lower the basket into the oil and replace the lid: back edge goes down first, then front of lid last. Set the unit's timer if desired, or just use your own timer. It will beep at you when your time is up. When you're done, you can wash the basket by hand or in the dish washer and wipe the unit off with a warm soapy dish cloth. Wait until the oil is cool to room temp before attempting to put the unit in a cupboard. Very hazardous with large potential for mess otherwise!
Dec 02, 2008 | Euro-Pro F1066 Deep Fryer
Rival CZF630 Deep Fryer Logo
790 people viewed this question
Top Rival Kitchen Appliances - Others Experts
ellenskitche
Craig Butler
Craig Butler
Barb
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
