1972 moblile home heater does not work automatically
The automatic switch does not work - If you turn on the switch the air blows but it does not autmatically shut off
  • 82 Answers
Alot of times those switches go bad and poeple just by-pass them those switches operate in this fashion...when you put the fan to automatic it will only come on when the heat or cool is turned on when you put the switch to on the fan will run continueously ie the switch usually will be labled Auto- Off - On
Posted on Jan 10, 2009
Will not turn on when set to automatic. when switched to on position no hot air comes out of vent.
If you are talking about the switch on your thermostat, "On" and "Automatic" refer to the fan. In the "Auto" setting, the fan only runs when the furnace is running, in "on" setting, it runs the fan constantly. Your furnace is not firing for some other reason, the on/Auto switch is working properly.
Dec 16, 2009 | Goodman GMS90703BXA Heater
No heating inside, just blows out cold air.
check your coolant- if it is low, top it off. you could have an air bubble or the heater core could be clogged. if not the air mode door in the heater box might not be moving. that is the hardest and last to check
May 26, 2009 | 2007 Ford Focus (3 Door) Hatchback
I have a 1972 Moblie home (Old) the pilot is on and the there is a switch you have to turn on to get the air to blow the automatic button does not work- If you turn it on it works but does not...
the fan/limit control (silver3x4 box cover pulls off has a dial behind cover with temp graduations) is prob.stuck or out of adjustment.
Jan 06, 2009 | Heating & Cooling
1991 cadillac deville NO HEAT
I had the same problem in my 1991 caddy, and turned out to be the blend door. It is located in back of the glove compartment. There are two kinds, the automatic blend doors and the manuel ones. Since the temperature is automatic and programmed to stay where it is set, it would be an "automatic blend door". Not a hard fix...
Oct 18, 2008 | 1991 Cadillac DeVille
I have a Ford BA Falcon but the heater does not work can you help
You'll most likely find your Air mix shaft has snapped - very common in the BA's and Territorys. Part only costs roughly $40, however the whole dash needs to come out so you can insert the new shaft. Less commonly it could be the HIM box
Aug 03, 2008 | Heating & Cooling
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
May 26, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
