Question about HP DesignJet 450c InkJet Printer
Poltter a disgnjet 500 is not alining
  • 67 Answers
Inspect the belt, if worn, machine will not align or print correctly.
Posted on Jan 10, 2009
I have a1998 skidoo 500 grandtouring handles horrible all over the trail. Darts all over. Ski adjustment? Suspension?
first check that your scags are good or new , now look at alinement of skis ,they should have a little toe in when looking from front of machine, if there strighr a head that will cause drifting left and right because skis get cought in ruts from other machines and causing pulling.
,also look for worn tie rod ends, or linkage from steering
.good luck hope you have fun out there .
Feb 15, 2015 | Cars & Trucks
Why does my 2006 Ford 500 shake while driving
may need a tuneup--electrical and fuel system---or motor mounts are worn--tires out of balance/alinement--steering
Aug 22, 2014 | Cars & Trucks
4 x 4 is not engageing. Mechanic told me that the electronics are not lining up the gears in the tranfer case? stated they were out of alinement. 500.00 to fix?
take it to another gears need electronic alignment,in any car.(mind you, i could do with $500........)there is an electromagnetic switch for the transfer box,but that is not $500 to fit.
just thought...i could fly over from england,fix it,have a holiday,and fly back, for not a lot more than $500.
Jul 15, 2010 | GMC Sierra 1500HD Cars & Trucks
1999 Polaris 500 ATV: Battery went shot. Just use pull start for quite awhile. After awhile, head light and low beam lights quit wokring. Replaced battery, all other lights work except those noted. Riding...
I had a simular problem with my 99 sportsman 500 and it turned out to be my pulse coil somehow became out of alinement. The pulse coil air gap should be between0.016 to 0.040 inch, But I would start by checking the coil it should read 0.3 to 0.5 ohms. Good luck and hope this helps
Mar 23, 2010 | Polaris ATV
My chain is very loose on my 1983 ascot ft 500 single cylinder, i believe it is the cam/chain tensionor has gone bad, is it possible that the chain is just not lined up properly and just needs to be...
Ok are you talking about the cam chain and not the drive chain? You cant re-aline a cam chain but you can a drive chain. Please give us better info on what is wrong.
Nov 20, 2009 | 1983 Honda vt 500 ft ascot
the cross or universals mus be in time thing of the U joint as a x the two x's must be alined so the swivel so if it has a short shaft on it take the alxe out and aline the U-joints so that when the drive line were sitting on the ground the caps will be on the bottom of the x and both x's bottoms should be in faze with each other, here is a simpe Example +------+ the top and bottom of + is stragith up and down and allows for the u joints to swivel also be sure that you have the caps in all the way and a needele bearing has not fallen down and is in the cap throwing the alinement off. This sounds like what yo have done. Next time before you remove a drivs shaft always mark the two pieces together before you remove, many people have done this so don't feel bad I did it my first time. If you don't understand this and need more help just send a replay tothe e-mail you get here.
Oct 09, 2009 | Polaris ATV
Not printing. Will not take in the printing paper. Information window tells me to aline the ink cartrage. I have replaced new ink cartrages. Somthing is trying to turn as it is making a ratchet noise. ...
yes you have to print out a alinement sheet then put it in the scanner and scan then follow the directions to aline the print cartrigde once it is alined you ready to go. and you have to do this each time you replace the cartridges.
Oct 07, 2009 | HP PSC 2175 All-In-One InkJet Printer
I need to aline a timing belt on a ford ranger 2.3l ,i am not sure how to aline the crank pulley . i found the dot on the sproket but don't know where to aline it to
go to and register for full free online repair manual with everthing you could need for your truck or any vehcile
Sep 10, 2009 | 1995 Ford Ranger Supercab
Alinement of blue cross with red and yellow.
you will need to call someone in to realign the picture...
Feb 16, 2009 | Pioneer SD-532HD5 53" Rear Projection...
HP DesignJet 450c InkJet Printer Logo
43 people viewed this question
Ben Johnson
