Mother Board Gateway MX6958
Ok I had a problem with my laptop recieving power I changed the cord the adapter and the DC power Jack took it to a computer repair man and he replaced the jack which it did need then still had the same problem when I went to power up the laptop It wouldnt even boot up it acted as though it was going to but nothing but a black screen and then nothing. I think I need a new motherboard but I have no idea what part number it is to replace it.
  • 594 Answers
In order to help you I will need you to take the laptop completley apart and get the model number off the bottom of the motherboard. it will say either intel than numbers and letter or asus than numbers or letters. but we need the model number of your motherboard so we can get you the part number. Or can you give me the serial number off the bottom of the laptop and i can try to look up your information that way and get you the information you need to get the board.
Posted on Jan 06, 2009
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
My laptop will not turn on the power supply is is fine gateway m6880
If laptop will not turn on and the power-supply is fine then it will be the computer itself and the only way to fix that would be a new motherboard due to the everyting oinside the laptop is pretty much connected to the mother board and not able to replace it without replacing the motherboard
Mar 28, 2011 | Computers & Internet
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
I have a MT6705 laptop that works with new battery but wont charge or operate with power cord.
Might be the power cord is faulty.If you have checked this with any other computer then inverter board on your main board is faulty or the dc in cable (the cable connecting power jack to mother board).
Thanks
Dec 30, 2009 | Gateway MT3705 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some alcohol...you can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Computers & Internet Logo
713 people viewed this question
David Payne
David Payne
