I have a 1972 Moblie home (Old) the pilot is on and the there is a switch you have to turn on to get the air to blow the automatic button does not work- If you turn it on it works but does not automatically shut off
    Problem Solver:
  • 13 Answers
The fan/limit control (silver3x4 box cover pulls off has a dial behind cover with temp graduations) is prob.stuck or out of adjustment.
Posted on Jan 11, 2009
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
I have switched my unit over to heat and only cool air blows out. Is there a reset button I can try before calling out a repair man.
It depends on what type of unit you have if it is gas or electric. If it is gas your pilot light is probably not lit .take the top door of your furnace off look under the burner and see if there is a small flame lit . if not it is simple to light turn the knob on the gas valve to pilot then push in on the know while holding a match at the pilot head to find the pilot head trace the small aluminuim pipe from the gas valve to where it ends that will be the pilot head once the pilot lights count to 10 slowly then switch the knob to the on position and your set make sure the t-stat is in the off position before lighting the pilot light.
If it is electric heat strips or a heat pump there is nothing to do other than turn t-stat to heat and make sure all 220 breakers are in the on position.
Nov 16, 2010 | Weather King Heating & Cooling
We have an intertherm heating system, its probably 30 or more years old, and we cant see a pilot light, and we havn't been able to light it. the model is mac 1175.
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Sep 27, 2010 | Intertherm Heating & Cooling
My gloworm micron 50ff is 6 years old and will not always light automatically without me turning the reset button. It will sometimes fire ok without any problem - I have just changed pcb board yet still...
Get a can of air used in the computer industry and use it up by blowing on the pilot assembly and any where you can get the straw into. Next take some steel wool or a scrub pad and polish the probes on the pilot assembly.
Mar 01, 2010 | Desa International GWP20T GLOWARM Wall...
Heat won't come on in auto mode; blows cool air in on mde(fan)
these units has 4-steps in heating mode... step-1 when the thermostat calls for heat, the small vent fan comes on and proves that its blowing thru the suction tube and closes a switch,,, step-2 -the next click from the gas valve, the pilot lights.......the #3 step and the next click from the gas valve the main gas comes on and heat up the box. step-#4 the box heats ups and turns on the fan switch and blows heat through out the home, now wheres the steps stops, thats where your problem is located>T Y V MUCH!
Dec 15, 2009 | Goodman CLQ36AR49 Air Conditioner
Can't find instructions on lennox gf 8 series furnace
Does it have a standing pilot light? On new units, there is an igniter and not a pilot. But if you have a standing pilot, you will move the gas valve to "pilot" and push down the red button while holding a flame under the pilot located by one of the jets. Once it lights continue to hold the button down for a minute or so and then release the button. The pilot should stay lit. Then turn the dial to the on position. That's it.......... If the pilot won't stay lit then the thermocouple is bad and needs to be replaced.
Apr 05, 2009 | Heating & Cooling
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
1972 moblile home heater does not work automatically
alot of times those switches go bad and poeple just by-pass them those switches operate in this fashion...when you put the fan to automatic it will only come on when the heat or cool is turned on when you put the switch to on the fan will run continueously ie the switch usually will be labled Auto- Off - On
Jan 06, 2009 | Heating & Cooling
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
