Question about Coleman Electrical Supplies
Checking the gas and oil levels?
Where on my Coleman portable generator can I check the oil gage of my generator. It is a coleman Powermate 6250?
  • 169 Answers
There isn't really a guage to look at . What one does is to take out the plastic plug on the side of the engine and with the engine cold and level make sure that the oil level comes up to the lowest thread where the plug screws in.
You really should have a manual, so if it's missing look here for which ever "PM" number is printed on the tag on the end of your generator.
Regards,
Carl
Posted on Jan 07, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
Have a coleman powermate 6250 model #pm0545007,won't start,what to look for?
Fresh Fuel
Clean carburetor if stored with fuel in the tank and wasn't shut off
Clean fuel filter
Clean air filter
Proper oil level
Clean spark plug (just replace it, it is easier and faster)
May 20, 2010 | Coleman Powermate Premium Plus 6250W...
I tried to start my new coleman powermate 6250/5000,
Do check the oil after it has tried to start. Low oil cutoff would certainly cause the problem. Look for the "lost" fuel shutoff valve... there usually is one.
Apr 24, 2010 | Coleman Powermate Premium Plus 6250W...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman powermate 6250 no spark, switch on, has oil. changed spark plug.
check wiring most likely loose wiring, happens when your generator viabrates
Nov 11, 2009 | Coleman Powermate Premium Plus 6250W...
Hi im working on a coleman powermate/pulseplus 1750 generator, i can not seem to get any spark, i cleaned the magneto,and fly wheel and still no spark,and i had the magneto check,the guy said theres...
As silly as this is going to sound, make sure the oil level is right. I have a Powermate 6250 that did the same thing to me. Turned out the oil was just a little too low and the sensor was killing the power. When you try to start it, the red light will be flashing in the on/off switch, that's the low oil indicator. Hope this helps.
Aug 28, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
171 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
