Question about Creative Labs SBS 450 Computer Speakers
Just got speakrs fer free. Cant find a place to attach speakers to computer
I go two satilites speakers and a sub-woofer. Where is the port on the speaker to connect to the computer? (I know where to plug it in on the computer, just not the speaker.)
The subwoofer will either be hard wired (just a cable with a 3.5mm jack to the computer) or a 3.5mm socket for a lead with 2 3.5mm jacks.
Posted on May 28, 2007
    Genius:
  • 2,985 Answers
The smaller speakers either have 3.5 mm jack cord on each to plug into the L R jacks on the subwhoofer or are hard wired Which?
Posted on May 27, 2007
How to open my sub woofer for my mhc gnz9d
Subwoofers are primarily designed as sealed cabinets but it often is possible to gain access inside by removing the speaker. I once had to extract a baby bottle that some child (or adult) shoved into the port.
Nov 11, 2014 | Audio Players & Recorders
Do i have to have the sub-woofer in order for my logitech X-230 speakers to work with my computer?
Certainly any large speaker itself cant be used with
very weak computer out signal
The signal should have power amplification in addition to
voltage amplification to energise large speakers
Oct 09, 2012 | Audio Players & Recorders
VGP-sp1
just do as I did cut the cable and attach to a store bought power adapter works good. I am only using a 12v power adapter and it seems to work fantastic
May 13, 2012 | Sony Audio Players & Recorders
Ihave hk395 subwoofer..but i dont have the satellite and a two speakers..it is possible to use it...if not were i can buy..
U can use the sub-woofer by plugging it separately with a normal 2 stereo speakers.. or ..use 2 speakers attached on it ..be sure they are powerfull enough to make a match ..(usually it is enough 10 watt )
to plug t separately ..just take a look in the speaker configuration option of the driver..and change it in such a way that will allow you multiple out ..(you will see which one will be what ...even on a normal sound card with only 3 plugs ..The configuration you have to choose is probably 3=1 or so ...and will leave your pink for a microphone ..and the line in will turn in a out-let for the woofer ..
Or if the woofer have inlets for the speakers and has a amplifier built in ..you can attach any speakers..
In this case you can use teh normal speaker out ..and get the signal for the other speakers from the woofer ..
In case they were separate ..and the woofer was only connected with the central ..use like I say ..a configuration on the sound manager (speaker configuration ) in such a way that you will be able to connect the speakers in normal green out and use regular 2 stereo ones..and attach the sub-woofer in the plug specified in the diagram ..usually for 3=1 or 4=1 it will change the blue line in into woofer out ..and will work
In this case the speakers used in the green out have to be amplified separately (or have a built in amplifier like computer speakers have ).please ask if you didn't understood the procedure ..and please rate my answer
Dec 25, 2011 | Dell HK395 Computer Speakers
I recently picked up the THC-c60 system without the supporting amplifier. Can I still use the subwoofer and the speakers without the amp? I note that it also came with a DIN cable, is there some way to...
You can use the sub-woofer and the speakers even without a supporting amplifier. The sub-woofer alone is powered with 167w per channel enough to power all the speakers. The DIN cables used to connect the sub-woofer to any source device like a computer, multi-media projector and others.
Dec 02, 2010 | JVC TH-C60 System
Could you tell me what plug in ports i need for X540 or 530- on my desktop
You need three ports in order to use all the speakers 5.1 sound. They are all headphone jacks but they are front speakers, rear speakers, and sub/center
http://www.newegg.com/Product/ImageGallery.aspx?CurImage=36-121-006-S04&SCList=36-121-006-S01%2c36-121-006-S02%2c36-121-006-S03%2c36-121-006-S04%2c36-121-006-S05%2c36-121-006-S06%2c36-121-006-S07%2c36-121-006-S08%2c36-121-006-S09%2c36-121-006-S10%2c36-121-006-S11&S7ImageFlag=2&Item=N82E16836121006&Depa=0&WaterMark=1&Description=Logitech%20X-540%2070%20watts%205.1%20Speakers
8th pic
Apr 06, 2010 | Logitech X-530 Computer Speakers
Ive got creative inspire T7900 7.1 speaker system attached to my pc.one of the speaker connections in sub-woofer is faulty ? the sub-woofer seems to be a sealed unit so cant take panel off to have a look...
Is this connecting to a sound blaster audigy 2 zs or xfi soundcard? or a motherboard onboard soundcard/ aftermarket Other than creative?
If connected to the creative card odds are the wire is bad. get a new one
If connected to a generic the wires for the speakers are proprietary and you have to go get 3.5 to 3.5 stereo cables to hook it up
Sep 04, 2009 | Creative Labs Inspire T7900 Computer...
How do i connect my logitech 210 speakers to the pc
the two satellite speakers (small ones) should connect to the sub-woofer. from the sub, there should be an "audio out" or "to computer" jack. from that jack, you should connect to the speaker port on your computer (usually a green-color port).
Oct 29, 2008 | Computers & Internet
Amatuer needs sub-woofer advice for Pioneer VSX-454...
Based upon your description, the subwoofer is just a speaker and is taken from the normal speaker outputs. Run your A channel to the sub and then from the sub to the left and right front speakers. That should do it.
Dan
Apr 08, 2008 | Pioneer VSX-454 Receiver
Creative Labs SBS 450 Computer Speakers Logo
138 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
