Question about Creda IWD12 Front Load Washer / Dryer
Creda IWD12 door latch broken. can't open door
Door latch on Creda IWD12 is broken. It just flaps about like the spring or what ever isn't attached behind it. Is there a way of opening the door ?
SOURCE: creda simplicity 1000 door hinge
I had the same problem and got a new one on ebay
Posted on Jan 16, 2008
barkencoa
  • 3463 Answers
SOURCE: my creda iwd12 front load is not working
If the m/c completed the wash cycle, it may be that the clothes have not rinsed, or incorrect prog selected, or incorrect temp selected,
Check to see if the drum actually goes round with clothes in, as a worn or broken belt will obviously stop the clothes from being washed.
Plz rate my solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: door lock broke and machine not start
You need to fit a new door lock.
Remove front of door seal, and fit new door lock.
Posted on Feb 10, 2009
barkencoa
  • 3463 Answers
SOURCE: Creda IWD12 makes noise when spinning but still works ok
Either a concrete balance weight is loose or broken, or the main drum bearings are worn. Spin the drum by hand, and if it feels noisy or rough, then it is the main drum bearings that have failed.
  • 5 Answers
SOURCE: door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Posted on Apr 04, 2009
Gas cap door won't spring open. Thanks for any help...
there is a broken spring / missing spring at the door hinge
it requires 2 people to get it open
one to keep the button pressed or cable pulled and the other to use fingers or maybe a flat bar of some sort to force the flap open
if you have the time it may be accessible from inside the boot behind the trim where you can undo some screws to free the latch mechanism so that the flap catch can come free of the latch tongue
springs are cheap and easily fitted as they break on a regular basis.
Sep 01, 2015 | 2007 Lincoln Town Car
I have a washer-dryer Creda IWD12. How can I reprogram the control PCB C00143471 as it seems to have the program for the washer only model. The drying LED acts as a door lock LED and the heater is con
return the machine from where it came from
its defective and not sold as claimed to be
so.. dont waist your time trying to fix its broken firmware
its defo a duffer...
Feb 08, 2015 | Creda Washing Machines
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Microwave oven door wont close
Most microwaves will have a spring loaded latch on the door. The likely issue is the clip for the spring has broken. Unplug it, put it on the benchtop and pry open the inside of the door. It's usually a soft plastic cover that with a gentle persuasion from a flat screwdriver will come off. Start above the latch and pry open as much ad needed. Locate the spring at the bottom, open up one of the fixing loops on the ends with long nose pliers and attach it to a fixed spot around the inside of the door. There are usually metal ribs inside the door and attach the other loop to the base of the latch
Mar 09, 2013 | Microwave Ovens
Creda iwd12 - how to remove the front
Its very simple to do when you fit them daily but first time is very difficult
Nov 03, 2012 | Creda IWD12 Front Load Washer / Dryer
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order parts here if needed.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 26, 2010 | Frigidaire Microwave Microwave Oven
Creda IWD12 Front Load Washer / Dryer Logo
74 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
