Question about Gateway MT3705 Notebook
Gateway laptop My laptop does not give me the option to burn dvds when installed. But i do have a dvd burner. When first bought, It did not allow me to burn cds. Tech suport walked me thru enabling process but unit is out of warrenty. Pls advise. Thanks
HL-DT-ST DVDRAM GT51N ATA CAN IT BURN DUEL LAYER DVDS
If it is not a dual layer DVD burner then it will not burn those dual layer disc.. Sould like all you have is a ROM read only
Oct 27, 2014 | Computers & Internet
I want to know how to make copies of DVDs and audio CDs using acer aspire 5742 laptop
Download and install Nero Burning Rom program, open it, set in the up window the option CD/DVD, get to preferite, copy CD or copy DVD option, depends by what you need, set the speed 4x for DVD or 8x for CD for have a good copy quality, insert the original disk, it will copy it, then insert the new disk to burn.
May 16, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dvd burner plays dvd's and cd's fine, will burn cd's but will not burn dvd's
Unless you have one of the very latest laptops, your model laptop most likely has a DVD ROM combo drive - which allows you to play DVDs and CDs also burn CDs/
You need to give me the make and model number of your laptop for me to verify if your laptop is capable of burn DVDs.
Jun 21, 2009 | HP Computers & Internet
I have problem with my AVERATEC COmputer
This is a common issue with NEC DVD burners, assuming that your NEC DVD burner cannot read and write DVDs anymore. I had a similar issue with my NEC DVD burner, which couldn't read and write CDs, but DVDs successfully. This is usually due to wear and tear of constant usage of the drive itself and sometimes mechanisms inside the DVD burner cease to work. While Windows Troubleshooting, uninstalling and re-installing the drive are suggestable, I am afraid the only option is a complete DVD burner replacement.
Feb 22, 2008 | NEC ND-3500A DVD±RW Dual Layer Burner
Can't burn movies onto dvd
in the software that u use to burn dvd...may be nero or roxio turn the dvd option on or select the dvd burning option.......u cannot use the xp writing sotware to burn dvds
Jan 01, 2008 | Pioneer DVR-112DSV DVD+RW Burner
Nti cd & dvd maker 7
try with other dvd writeing software like nero or roxio or you can try your own nti cd & dvd maker by re-installing bye
Sep 23, 2007 | Acer Aspire 5003WLMi Notebook
Hello
Assuming you have a dvd burner, do you have dvd decoder software or dvd burning software installed? Does it read burned dvds? Are you sure it's a dvd burner? If so, make sure the blank dvds you are using are the proper format ie; dvd+/-rw, etc. Good luck
Aug 19, 2007 | Acer Aspire 3624WXCi Notebook
Can't Burn Dual-Layer Disks
First, be sure your DVD burner is capable of burning dual-layered discs- Second, it may be rather an issue of copy protection on the disc. Have you succesfully copied commercial DVD's in this fashion? I'm unsure if I'm allowed to mention any software that might assist you in that regard- google is your friend.
Apr 23, 2007 | LaCie (300775EK) DVD±RW Dual Layer...
Gateway MT3705 Notebook Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
