Question about Crunch BlackMaxx BLX2000D Car Audio Amplifier
Amplifier stop working
I have a Kole Audio 980watt amp that was powering a 15"Cadence Mallet. I was driving down the road and all of a sudden my amp stopped working.When i got home i checked every possible thing that could be wrong.I took my amp apart looked for burnned diodes,not really sure how to check pre-amp though.I checkd all diodes on each side with a volt tester, and they all seem to be getting about 12.1 volts.The LED light went out also and i havent been able to get it back on. Ive played with it quite a bit, and quit franclly Im gettin sick of it. If i cant get answers from here i will toss it in the trash and buy a new one.
Try rewireing the whole amp wireing kit
Posted on Aug 31, 2008
This problemis your amp is dead powerflux you need the asistance techinic
Posted on May 27, 2007
My kole audio amp protects when powered
you read amp catalogue there written it briefly.
Mar 27, 2013 | Kole audio Nitric XP4-1000 Car Amp
It worked for a week and now im getting no power to my subs
if it stopped suddenly i would check the fuses and work your way back to the where the remote start wire is attached. if you where pushing it hard the fuse is likely. also check the connections on the amp closely.
Jan 28, 2011 | Sony HK720-4 Kole Audio 4 Channel Car...
What sizes fuses go from battery to the amp on the kole audio 1920 watts kx2-1920?
depends on the size of your amplifier. what size is it? and how many channels? and what class?
Oct 22, 2009 | Kole audio KX2-1920 Car Audio Amplifier
I have a 2400 kole audio amp also have 5 EVs connected to that amp, I have had monster power but with in the next week the power I had faded away. How can I get the power I have had back?
you are lacking batterie juice ?
need to replace your stock with a yellow top and
add another to the truck close to you amps !! should work great !!
Mar 09, 2009 | Kole audio QX1-2400D Car Audio Amplifier
Kole kx2-1440 wiring da amp up right
It is correct to connect the amp turn on wire to the amplifier remote. 5V is sufficient to turn most amplifiers on... It should be 12V optimally.
If the amplifier is not turning on with the ant. remote, the problem is with the amplifier.
Dec 30, 2008 | Kole audio QX1-2400D Car Audio Amplifier
Kole audio q1-3000d
This amp is similar to many of the planet audio class D amplifiers. These amplifiers have quite a few problems. If the amplifier has failed, it needs to be serviced by someone who is familiar with the amplifier.
Do not repeatedly replace the fuses. It will lead to more damage and a more expensive repair.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Kole Q1-3000D Power Supply caps Keep blowin
you need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
Cadence z1200 stays in Safe Mode!
If the subs are rmoved from the amp (wiring), does the amp still go into protection without them hooked up? If no, shorted sub, if it still des, unplug RCA's, does it still go into protection? Also check voltage. Make SURE you have greater than 12 volts AT THE AMP using amps ground to check the power AND remote wires. Hit me back wth an update.Those amps rock.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Sep 17, 2006 | Cadence Z8000 Car Audio Amplifier
Crunch BlackMaxx BLX2000D Car Audio Amplifier Logo
187 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
matthew walsh
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
