SOURCE: babylock
The arms are serial numbered to match the machine. Each series esante is different.
If you can get me a serial number (off the back of the machine) I will tell you which series you need to order. I can get it through my work.
SOURCE: Will not accept memory card
I loaded a different pattern to the card and it worked. Guess it was just a problem with the first one I tried. Hopefully, it won't happen again.
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
SOURCE: looking for a babylock esante manual. ESe2. The
I have a manual for the ESe2. If you still need it let me know
SOURCE: embroidery arm and hoops for an esante
Try Ron at a1sewingmachine.com. If he can't try Wendy at [email protected]. Hope this helps.
