Question about Dell Inspiron 1525 Notebook
No internal hard disk found after laptop is closed?
I turned my Dell Inspiron 1525 on, and everything ran like normal. I got done, and instead of shutting the machine down, I just closed the laptop, causing it to go to sleep. Well, normally, I open the laptop back up, and it wakes up and nothing is wrong. However, every once in a while, I'll open it back up and there is a black screen that says something like "no internal hard disk found." After removing the battery to turn off the laptop, it comes up normally. The diagnostics suggested to reseat the hard drive, and I did that yesterday, hoping to fix the problem. The fix has not seemed to work, as the laptop has had this error again today. Thanks!
  • 4 more comments
  • hinata16 Jan 15, 2009
    i have the same problem with my dell 1525. :-( it's an intermittent problem. i dont know what's wrong with it.
  • howe0 Jan 18, 2009
    I have the same Dell 1525, and some times i get the same message.....I have to turn it off ( by holding the power button in for a very long time) and then it usually comes back working normally.
  • funkinfurdro Mar 01, 2009
    same exact problem
  • skygirl1989 Apr 07, 2009
    All the time!! and sometimes wen i press the sleep button it just restarts the stupid laptop, and sometimes when i close the lid it just shuts down, and sometimes it just does any and all of the above just cause it feels like it...and i was told by dell to take the hard drive out and put it back in...it did squat!!
  • Anonymous Apr 19, 2009
    Same thing, they sent me a new hard drive..And the prob started up again. And they want 50$ just to talk to them. And the customer server wasn't friendly and didn't help. Going to try and remove optical drive.
  • ecl12345 Apr 21, 2009
    I shut down my computer properly, closed it, and two minutes later wanted to turn it back on and received that same error message "No internal hard drive found." I then held the power button to force power-off, and then restarted it, and only on the second try did my computer load up again. I recently had some other issues with Vista Ultimate and had to reformat my computer, so is this related to that reformat?
    Problem Solver:
  • 19 Answers
To fix this problem you would need to try this.
*Run the psa test
1. press the 'fn' key and power key together, it will automatically launch a diagnostic test, follow the onscreen instructions confirm if it comes with any error code (it should come up with 0141 error code if it is a hard drive problem).
2. check the hard drive status in bios (check if it is being detected).To do this you would need to switch on the laptop and start tapping F2 key (multiple times, especially at dell logo). this will lead you to bios. using the down errow key on the keyboard, go to device info and check the first option on the right hand side (primary hard drive). confirm if it is detecting the hard drive or it says none or unknown.
3. Remove the optical drive by following the link (support.euro.dell.com) and check if it works after removing the optical drive. This is because optical drive can cause the hard drive not to work properly as they are interconnected with each other.
Once you have performed the above steps, confirm so that I can suggest you the rest of the steps accordingly.
Regards,
Musheer.
Posted on Jan 06, 2009
  • 3 Answers
First think ur harddisk is shot can u change ur harddrive
CptOblivious
  • 5 Answers
SOURCE: reseat the hard drive
shut down the laptop.
then, disconnect the laptop power, and battery.
remove the harddrive, then connect the harddrive firmly back into place.
reconnect power/battery and boot.
Posted on Mar 25, 2009
SOURCE: my internal mic of dell inspiron 1525 is not working
my dell inspirion 1525 microphone is not working. when i am on yahoo messenger i hear the other person but they can't hear me unlike before i use to hear the othe person because there is an in built mic.
Posted on Apr 11, 2009
cabanagj43
  • 225 Answers
SOURCE: I ran diagnostics on my Dell Inspiron 1525.
1. reseat the ram
2. at the buttom part of the laptop you will see a window covered which will allow you to remove and have the ram be reseated.
3. take out 1 ram firs then run test then run again the test using the other slot. please test each ram on each slot. check if the faulty if the ram or either of the rams of one of the slots. if both ram passed on one of the slots means that ram is ok and slot is not, so then replace the motherboard. if one ram errors on a slot which the ram passed then that ram might be faulty and needs replacement.
Posted on Oct 15, 2009
computus
  • 487 Answers
SOURCE: have a Dell Inspiron 1525
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Posted on Aug 04, 2010
  • 998 Answers
SOURCE: My year and a half
Your hard drive is defective. The clicking noise you hear are the heads trying to load. For info on how a hard drive works copy and paste this link on your internet browser:
http://computer.howstuffworks.com/hard-disk5.htm
Posted on Feb 21, 2011
I get no internal hard disk found
You must check if the Hard drive is failure
see the Hard drive light - In front your laptop is led shoiw like a cilinder
Light Turns must turn on If is blinking light indicates hard drive
activity
To diagnostic your laptop fololow these step
1.- Turn on your laptop
Press key "F12
immediately.
Select Diagnostic
If Hard disk is not detected you need replace the hard disk driver
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Inspiron 1525 Notebook
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
Sep 12, 2011 | Dell Inspiron 1525 Notebook
Laptop dell 1525 : power on but no hard drive activity,then later turns on normally (window vista ,normal)and then frozen and after restart no hard activity again but power is on???
You can try running the DELL diagnostics which came with the computer or you can download them off another computer from the dell support website.
Once you get in the diagnostics package. Check the Hard drive, there will be a few testing parameters for the disk check them all.
If the hard drive fails in even 1 test, note down the error code and provide it to dell support who will replace the hard disk if it is still under warranty.
If you dont have warranty then you may need to buy a hard-drive yourself and have it fixed.
Feb 23, 2011 | Dell Inspiron 1525 Notebook
I have a two-year old Dell Inspiron 1525 laptop. for no apparent reason, it will now not boot up. When I turn it on, I get the following message......"Internal hard disk not found. To resolve this...
The hard drive may have failed or a virus has corrupted the Cmos data.
Try entering the BIOS and checking that the Cmos recognises that the hard drive is there. If it doesn't, remove the hard drive and re fit it, booting up again.
Dec 27, 2010 | Dell Inspiron 1525 Notebook
Says internal hard disk drive not found, to resolve this issue, try to reseat the drive
The hard disk has died, you will have to replace it with a new one then reinstall Windows using the recovery disk.
Dec 10, 2010 | Dell Inspiron 1525 Notebook
GET MESSAGE INTERNAL HARD DISK DRIVE NOT FOUND ON INSPIRON 1545.
Do harddisk is detected in bios setting if no?? so ur harddisk got crashed??and you have to replace ur harddisk
Sep 08, 2010 | Dell Inspiron 1525 Laptop
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
Aug 04, 2010 | Dell Inspiron 1525 Notebook
No internal hard disk found during booting when i am going to format
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
May 24, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
5,173 people viewed this question
Alun Cox
