Question about Protron PLTV-32 Television
No HD picture
It seems the 32" Protron will not get a HDTV picture. We hooked up the composite cables coming from the HDTV tuner box supplied by Cox to another set and it gets the HD just fine. But this set jusy wont get them. The owner swears that he got them before but not now. We changed the source many many times to no avail. He gets the HD channels but they are not HD pictures. ???
Protron (now SpectronIQ) says HD only works if the component cables are in Comp2 on the set.
Posted on Oct 24, 2007
I need to know what hooks on the back of the TV into the mother/sister to provide regular TV. Some sort of converter? Which kind?
The Protron PLTV-32 only has an analog tuner (NTSC). So you need a digital to analog converter to watch OTA programming. A basic d-t-a converter will give you Standard Definition output (480i) (either on the TVs antenna in or the composite in inputs).
Since the TV can show a high definition signal (720p), you could also use an HD tuner set top box. However, these are significantly more expensive than the $40-70 SD converter boxes that were sold for purchase with the government coupon last year. Alternatively you can use a DVR with a tuner as your set top box (computer with a tuner card) to the VGA or DVI inputs on the TV.
I hope this helps.
Aug 16, 2011 | Protron PLTV-32 Television
I have just hooked up set top box to Sharp TV CX5182 and need to re-tune it? Can you send me instructions please as I can't find my operators manual. Many thanks.
By set top box do you mean a digital tuner box? If so and your tv is a newer flat panal than more than likely you wont need it anymore. That tuner will be built in. If this is the case than hook your anntena up to the new tv and go to the menu to do an auto channel search. That should do the trick. If it is an older tv and doesnt have the tuner then hook up the box the way you hooked it up before IE if you used cable than hook it up with cable if you used it with Composite cables(RCA) than use those the reason is some of those boxes you have to set that part up in the settings and that disabled the other output so if you had it set for cable than hooked it up with Composite(rca) nada, nothing would show. Once you hook it up and you see it on the screen then your good to go simple channel search from there. Also if you use cable then your tv needs to be on channel 3 or 4 if you use Composite(rca yellow red and white) then your tv has to be on the input channel that coencides with what input is hooked to.
Dec 13, 2010 | Televison & Video
Ok I have no skills when it comes to this stuff but can figure out the basics, i have basic cable now, and cant for the life of me figure out how to hook the cable up, i have a converter box already and...
OK! First, you have NO TUNER in that model. It's called a monitor. You have to use a cable box, satellite receiver or use an older style vcr with a tuner in it. With the vcr you won't see HD stations that broadcast in HD. You will see the old style analog.
Dec 10, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Model l32hd31r will not work with cox cable box.
The Cox cable box,work before?Talk to Cox cable customer seviced send u another box?Tries unplug the tv and the cable box,replug the tv and the cable box back an hour later.Tv should reset itself back to factory setting.The cable box should update it software.They might work,if they reset themselves.
Oct 06, 2010 | RCA L32HD31 32 in. LCD HDTV
How do I get the HD on this model? Which cables/hook up should I use? I do not have a cable box or set top box but if these are required, please let me know. Thanks!
Your unit is HDTV ready but is not an HDTV. It is capable of displaying HDTV only through the component inputs. Your tuner is analog NTSC and will not receive HDTV or digital.
You could get an HDTV picture using a Blue Ray DVD and hooking up the component connectors from the DVD to the TV.
The only other way would be to get an HDTV tuner with a component output and hook it up the same way, component out to component in, and hook the tuner input to an off air antenna (receiving HDTV) or cable or satellite with HD signals.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 21, 2010 | Sony KP-51WS510 51" Rear Projection...
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
Protron PLTV-32C, 3 years old Have always used the cable remote to turn on TV. Cable turns on. TV will not turn on but, redlight is on. Tried powering manually, tried both the TV remote and the cable...
Tries unplug the tv and the cable box about an hour and replug both.See if the tv reset it self and the cable box reboot it software.Not,than the Tuner board is dead,that the board the coalax signal cable plug into it to get the broscasting signal.
Jul 14, 2010 | Protron PLTV-32 Television
My cable TV company is COX. I am getting the
Unplug,replug the cable box for an hour later.Let the box boot up,and upgrade the softwares.Might have go to ur tv menu to rescan all ur channels again.If this don't work call ur cable company might have to change the box.
Mar 30, 2010 | Protron PLTV-32 Television
I have an HD cable box from COX, but I can't get HD... but I do get the HD channels, just not in High Def.
you need to make sure your hooking it up with componant in or hdmi in NOT coax
and you should be alset
Nov 28, 2009 | LG 32LH30 32 in. LCD HDTV
Protron PLTV-32 Television Logo
64 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
