Question about Jenn-Air JMC7000 Microwave Oven
Need to replace JMC7000 Microwave
Everything works except microwave will not heat food and has a burning electrical / insulation type smell. Repair is coming out in a few days, but in the meantime, I want to know if another Jennair model will fit in the same footprint in the built in oven-microwave combination. I cannot locate anyone locally with Jennair microwaves but would like to know model and approximate price of a new one so I can decide what to do based on what the service call shows.
  • Anonymous Jan 16, 2009
    looking for a replacement jenn-air JMC7000ADW to replace one not working well
  • Jenn-Air Master
  • 9,086 Answers
Yours will likely have a bad high voltage diode, transformer or magnetron, all of which are covered under the extended parts warranty for five years from the date of purchase!
All you have to pay is labor, unless it's less than the two-year full warranty, then there's no charge.
That's a really great warranty!
It's on the back page of the owner's manual.
If you opt for replacement, Jenn-Air Customer Care can tell you which model would be a "drop-in" replacement.
Posted on Jan 09, 2009
Electrical burning smell
It is hard to tell what is burning, take it to the repair shop
Mar 12, 2013 | Oster OGG61403 Microwave Oven
JVM16331BB005 over the range microwave oven will not heat everything else works ok
That is a sign the magnetron has shorted and is the most expensive part to replace.
Apr 28, 2012 | GE Microwave Ovens
MMV5100AAW Microwave hums and smells burnt , will not heat food , everything else works fine
If you have that funny burning smell in the microwave oven This is sure sign the magnetron has failed, and must be replaced.
Mar 21, 2012 | Maytag MMV5165 Microwave Oven
Microwave Heating Problems
Magnatron or the HV Transformer. Each has a distinct odor, Mag is heavy and thick burning smell transformer is more electrical. Eric
Aug 04, 2009 | Microwave Ovens
My microwave will not heat. Everything else works.
hello. i can help you.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Jun 15, 2009 | General Electric Microwave Oven
MY SAMSUNG MW6574W OVEN FUSE BLOWS AFTER 4-5 MINS OF REHEATING-NO SMELL OF BURNING -EVERYTHING ELSE WORKS FINE- NO LOOSE WIRING-ALL BULBS WORK FINE TOO- THE FOOD HEATS UP FINE EXCEPT THAT THE FUSE BLO
the insulation of the wiring has detiorated and with temperatue rising it further deteriorates. thus increasing the current consumption and blowing the fuse
May 21, 2009 | Samsung MW6575G/MW6574W Microwave Oven
Jenn Air Microwave won't cook
I had the same problem with mine wich is the same built in Jenn Air jmc7000 after using an ohm meter to check some of the switches I discovered the door swith was bad replace it for about 5 dollars and it works as good as new...Good Luck
Jan 04, 2009 | Jenn-Air JMC7000 Microwave Oven
GE Spacemaker microwave won't heat food
hello kmwnky,
You say that Everything went out at first ( which I assume means that all functions went dead) and then functions started to operate again later... if that is correct and you smelled something burning.. you may have a thermal fuse that failed, filament transformer that failed, magnetron tube that failed or a highvoltage capacitor that failed.. None of these components are something the untrained person should attempt to trouble shoot or replace since there are dangerous energies stored inside the electronics compartment even after power is removed.. Your Micro is > 8 years old and it's probably not worth the cost of repairing at this point. You'd be better served replacing it.. The cost to repair would exceed the cost to replace.. ( I feel like the grim reaper here..sorry..)
Regards,
Rick
Nov 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do I fix a Jenn-Air JMC7000 that does not heat up items?
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 06, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
282 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
