Question about LG 24 in. LDS 5811 Built-in Dishwasher
Door hinge adjustment to LG Dishwasher
I have an LG dishwasher - LDS5811BB.  The door hinge needs adjustment.  LG won't tell me how to do the adjustment.  Any clue how to arrange this ?
    Sniper:
  • 88 Answers
There is no adjustment to the door hinges. If your hinges are failing they will need to be replaced.
Posted on Jan 18, 2009
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
Door won't close
1) adjust the latch
2)see the spring if are broken or without tension replace or repair
3)hinges bent, replace
4)door seal, try to adjust or replace
Jun 19, 2012 | Whirlpool 18 in. ADP530 Free-standing...
Leaks from door gasket.Should I change the gasket or the whole door? Thanks
Replace the door seals/gasket.
You also have adjustment on the door hinge springs. You need to remove side panels to get to the hinge adjustment on the sides and tighten them. Sometimes the chasis of the machine gets bent from the weight of the door.
If you need instructions on removing the side panels let me know.
Ash
Sep 13, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Are there any service bulletins available for the LDS5811BB LG dishwasher?
Yes there are several bulletins for this model number and for different years.
Jul 19, 2010 | LG 24 in. LDF 7811 Stainless Steel...
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Door seals for dishwasher lds5811bb it is leaking water and all I want is a diagram of parts so that I can order the right ones. I need the tub seal and the door seal.
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Jan 19, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
LG dishwasher won't dry
Recommend you confirm that the rinse aid is not empty.
If problem persists and you are not getting an error message, contact LG service and pres them for the retrofit they released for the LDS5811 (and other models) that dramaticly enhances the drying ability. Until it is replaced, be careful because it is possible tht water will leak from the door panel (not directly from inside the diswasher, but through the door panel-based drying system.
Press them for a no charge repair for this problem and be persistant, firm but polite. If the agent is not helpful on their own, request to be "escalated" to his/her manager. Good Luck! and report back what you find. Thanks!
Mar 29, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS5811BB Dishwasher
Some of the LG LDS5811 had problems with the wiring harness in the door panel. This is nothing to mess with unless you have disconnected the DW from power.
You can open the door panel by removing the screws around the inside edge of the DW. Or, better yet, firmly but politely contact LG service and tell them you are aware of LDS5811 dishwashers having these symptoms being caused by _melting_ wires in inside the door panel. This is true and even if the DW is out of warranty, LG should fix this problem at no cost to you.
Good Luck!
Aug 09, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
1,398 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
