Question about Coleman Powermate Powermate 5000W Generator
Power mate Powerbase 5000W generator
This gernerator has a pull cord. I am not strong enough to start this engine so I would like to install an electric start. Is this possible? I am not sure if it has a subaru engine or a briggs & straton. engine. Where would I purchase parts and approx. how much would it cost for parts?
Thanks
Barb
  • Anonymous May 25, 2009
    Where can I get the parts to set up my generator a Subaru 5000, so it will be automatic start?
SOURCE: Coleman Powermate 5000W generator - Won't stay on
add some oil they have a low oil shutdown
Posted on Nov 06, 2008
SOURCE: generator runs for a short time
does your generator have a metel tank? If it does it probley has rust in the shut off valve under the tank.
Posted on Nov 30, 2008
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
mamicheddy
  • 79 Answers
SOURCE: Powermate 5000W generator Tecumseh HM100 159409P
I recommend that you purchase your air filter at -
tewarehouse.com
They offer the lowest prices that I have seen and it is good quality.
Posted on May 09, 2009
sal_kh_sab
  • 98 Answers
SOURCE: 5000w gen. no powe out put
when engine runs but no power is produced ...there are three things you need to check:
1- brushes may be shattered.(open the generating unit cover(from the stator and rotor side) and you'll find it..if it is shattered..then replace it.
2- breaker...to test this disfunction...connect the two wires(the one going to it and the one coming out of it) together and try again...if it generated power..then the breaker is out of order...either replace it...or keep it connected directly (DON'T leave any naked wires)
3- AVR open the generatng unit cove again.you'll find the AVR (screwed to the rotor holder) here is a picture of an AVR:93c8b52.jpg if it is burnt out...replace it..
IF you tried the 3 things i wrote and none of them worked, then you have a problem with the stator or the rotor...but that is very rare to happen...it's probably one of the three///..
Posted on Oct 26, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers Ā· I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Starter rope is locked. Cannot turn by pulling cord
Hi Bob:
Sounds like the engine is seized.
Try removing enough bits so you can access the flywheel and see if you can turn it. Make sure ignition is OFF.
If the flywheel does not turn it will be time for a learning experience, a trip to the maintenance shop, or a replacement.
Sep 16, 2015 | Coleman Powermate Powermate 5000W...
How do i start a powermate 5000
choke it and pull the cord, if it has set for a long time, you may need to pull the spark plug and put a drop or 2 of gas in the cyilinder, reinstall the plug andwire and it should start.
Aug 27, 2011 | Coleman Powermate Powermate 5000W...
Gernerator wasn't used over a year, tried to start and can not pull cord. Checked the oil and there is gas in it?
The rings are stuck to the cylinder wall. Remove spark plug and spray some pb blaster in the hole.
3 or 4 seconds worth. Let sit a day then try. If no go repete. You can pry on the flywheel if yiu know where not to. Take your time Rushing it may brake the rings.
Feb 11, 2011 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
Sep 05, 2009 | Coleman Powermate Powermate 5000W...
Won't start
low oil switch stuck. most new small engine have a low oil swich in the oil pan. this can be by passed or replaced.
Dec 21, 2008 | Coleman Powermate Subaru 5000W Portable...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Coleman Generator powerbase 4000 model #PM0543800
I have to leave a comment for cfa6094. Your pretty good at flexing your cyber muscles. I am a service tech in the repair field and deal with people like you all the time. If you are the owner of the equipment you should properly maintain your equipment. Sounds like you are not very organized. Sound more like crises management to me. Is mrfixit the only person you asked about this problem? One more thing, sound like you are a bit of a procrastinator to me. LOOK AT ME NO SPELL CHECK!
Oct 11, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
829 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
