Question about Whirlpool LGR4634J Gas Dryer
Whirl pool Dryer not staying hot
Recently, my dryer started to act up. What it is doing is this: When you first turn it on, it heats up and you can see the flame. This only lasts about a minute or two and then goes out and you get no heat. If you shut it off and wait, turn it back on you get the same results. If you turn it on right away, it doesn't even try to heat up. I have taken the back off and cleaned everything. I have ran it with out the vent hooked up. The second thing it is doing(may have been doing this for awhile without us noticing) is that on one setting, the timer does not move and the dryer will run and run....never getting hot.
  • 2 more comments
  • John Ryan May 27, 2007
    OK, 1 more thing. I did take everything apart and clean it to assue there was not lint build up anywhere. When it stops heating and i open the door, close the door and restart the dryer, you can see the orange glow but never lights back up.
  • petersax99 Jul 30, 2008
    I have the same symptoms - it heats when first starting, but doesn't stay hot. It runs forever, but doesn't dry the clothes.. How do you know if it's coils or thermostat?
    thanks,
    PEter
  • Anonymous Sep 06, 2008
    cleaned all parts
  • Michael T May 11, 2010
    how do you access the gas valve coils, please? I looked at the burner tube...I see no way of accessing even the glow rod
  • 23 Answers
You need to have your gas valve coils replaced good luck
Posted on Jun 02, 2007
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: Whirl pool Dryer not staying hot
Ok, if the timer is malfunctioning, i recommend replacing this device asap. this can be the central issue. the timer is the brain and, if it is not functioning at optimal range, it will effect all components and the way they operate. replace th timer asap.
I would also check the following to address the heating issue as well but, im sure the fualty timer is the cuase.
Check the following before replacing the time just to be sure.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 03, 2009
localwonder
  • 6784 Answers
SOURCE: whirl pool elect dryer keeps tripping breaker
Ok, this is the result of a failed High limit thermostat. you should replace this failed device asap.
Check for continuity in the thermal fuse as well. replace if no continuity is found.
Posted on May 31, 2009
Wed8300swo whirl pool dryer replace motor you set all setting push start nothing comes on but the heat
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 08, 2010 | Whirlpool Dryers
1. Gas valve coils
2. Thermal fuse
3. igniter
Jun 03, 2009 | Whirlpool LGR4634J Gas Dryer
Whirl pool elect dryer keeps tripping breaker
May 31, 2009 | Whirlpool LEB6300 Electric Dryer
My whirl pool dryer has to be turned on bout 3 to 4 times
Ok, check the exhaust hose for obstructions. make sure the blower assembly is not clogged and, the hose is clear of any debris. the exhaust hose should blow out hot air forcefully. if the force of the air isn't blowing hard, it will not create a suitable drying environment for the element. this poor ventilation will also damage the heating element or burner Assembly.
Now, if there is sufficient air flow out of the exhaust hose, this will confirm control failure. replace the dryness sensor and control board in this case.
Here's a quick way to test for clogs. take the hose of the backside of the dryer then, start the cycle. if the drum sorts to become hot after a few minutes with the exhaust hose removed form the back of the unit, this will confirm a major block in the hose or blower assembly.
May 29, 2009 | Whirlpool Dryers
Dryer does not go past wet cycle
if your vent hose is clogged, your element most likely burnt open
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirl pool dryer does not dry?
coil never gets power usually a sign that you have a blown thermal fuse , small white 2in' fuse located behind rear panel, there should be a wire diagram behind the console, few screws acrosss the back
Oct 30, 2008 | Dryers
gary suspect the coils on the valve are bad the coils come in a kit so change both
May 18, 2008 | Dryers
Whirl pool dryer
L1 Hot= Left terminal (Red Wire) ...... L2 Hot= Right side terminal (Black Wire) .......... Netural = Center terminal (White Wire) .................. Ground is Green connect to the cabniet of the unit and remove the connection strap from the center terminal on thje dryer wiring block..
Feb 22, 2008 | Kitchen Ranges
Whirlpool LGR4634J Gas Dryer Logo
662 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
