Question about RCA D52W19 52" Rear Projection Television
Unit shuts down (D52GW12)
I have found the cp's but am wondering what is the best way to remove the board(if if have to) to replace them. The 150 has a slight bulge on the top.
Tnks
J.C.
  • disisjc Jan 06, 2009
    Thanks
    I got the board out and replaced the 3 caps but when I powered it back up it blew cp120 up. Do these caps have a certain way to go back in?
    Tnks again
    J.C.
  • disisjc Jan 07, 2009
    Thanks a whole lot,
    Saved me a bunch of bucks. I got the caps in correctly and now tv is purring like a kitten.
    J.C.
  • RCA Master
  • 5,138 Answers
There is little plastic clips that hold board in push them back and slowly lift chassis up and out. and since you said cp150 is puffed up replace all 3 capacitors on cp150 2200uf 16 use a 25volt,other 2 use same 220uf 35v.cp114 cp120.
Posted on Jan 06, 2009
  • ladywinn
    ladywinn Jan 07, 2009
    Yes you have to put them in neg- goes to - and pos+ goes to + make sure they go back in same way or they will blow up because you have reversed politiy.Look on board it has black line - where neg side goes.
  • ladywinn
    I am very Happy That your TV is Fixed. Now you can Watch TV the way it was meant to Be!
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52gw12 flyback replacement
Board has to be removed and flyback disconnected and then all pins unsoldered.
May 24, 2012 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 TV TURNED ON WORKED GOOD FOR 3 MIN THEN SHUT OFF . WENT TO TURN IT ON AGAIN AND GREEN POWER LIGHT BLINKED AND HERD A POP OR CRACK NOISE ..NOW DONT TURN ON . SEE 1 OF THE TUBES FLASH IN FRONT 1...
The CRT on the left will need to be replaced. You can test it by removing the CRT drive board from the bottom of that tube and leaving it suspended without unplugging any wires. try plugging it back in and pressing power. If it powers up with that drive board hanging off the bottom of that tube then you know thats the issue and the CRT ( tube) will need replacement. You can get the replacement CRTs ( tubes) from www.tvrepairworld.com
Jun 14, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Replaced cp150 @cp114 plus flyback. tv runs great but not full screen.
Hi
Thanks for using FixYa. On the Deflection board there are 3 capacitors CP 114, 120 and 150. If you have already replaced two of them then replace CP 120: 330UF/35V/HF and post back if that makes any difference.
Thanks Rylee
Jun 05, 2010 | RCA D52W19 52" Rear Projection Television
GE Model# D52GW12 Television works good for
The small signal board is usually at fault when that symptom occurs. You can get replacement boards from www.tvrepairworld.com
Apr 02, 2010 | Televison & Video
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Will not power up
If youre not getting a power light then its most likely the AC main filter board ( Where power cords plugs into ) or if you do get a power light the deflection board needs replacement.
Dec 11, 2009 | RCA D52W19 52" Rear Projection Television
Same problem. GE Model #D52GW12 Working fine then just caught on fire. Removed the back and found a part that said "Focus and Screen" on it. Can this be replaced or do you have to replace the circuit...
the flyback... very common for the ge version of the rca it222 you may also have to replace the horizontal output transistor. i have found at the shop the flyback and the transistor ussally all that have to replace
Apr 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Capacitors
Sorry i am very sick with the Flu But the 3 caps you are looking for are on the deflection board which has the flyback on it Also all 3 caps will be green with gold writing cp 150 is 2200uf 16v use 25v the other 2 caps are neer by this one.
Nov 05, 2008 | RCA HD52W59 HDTV Projection Television
Power button flashes 3 times but not turn on i here a sound in the back of the tv but tv will not come on was wondering if there are any easy checks or what might be a common problem for this and HOW DO I...
If you take off the back cover, cp 150 is located on the left circuit board. There are 3 or 4 C-shaped metal heat sinks in the board, and capacitor cp-150 is located inside the furthest one. Once you find cp 150 check the top of it to see if it is still flat, as opposed to puffed up. If it is puffed up I am almost certain this is you problem.
My tv would flash green 3 times and turn off for 45 seconds. It was taking up to 20 minutes to finally turn it on, so I bought a pack of 5 capacitors off of ebay to replace capacitor cp 150, which is just a (2200uF,16V) capacitor. I replaced it 10 minutes ago, and the tv turned right on. Fix Ya!
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
59 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
