Question about Ruud UAMB Air Conditioner
Combustion Fan runs all the time
I have a RUDD Model #URGG-10E36 JKR (I think this is the correct numbers). I need to purchase a schematic for the unit, and a possible solution to the problem that the Combustion Fan is running all the time.
  • dwkcool May 11, 2010
    sounds like you have a bad high limit switch but check for a flash code
  • 96 Answers
The schematics sould be on the back of the door panel
Posted on Jan 06, 2009
Ubhb-21j11sfdai: what motor should be in this blower? HP, RPM, Voltage, Amp?
If you have the motor from the blower, the information should be on the motor nameplate. If there's no nameplate or information on the motor. Then to get the correct motor for your blower, you need to call your local Rudd dealer or local parts store. Give them the model number and serial number of the Rudd unit and they should be able to help you.
Jun 11, 2013 | Ruud UBHC Air Conditioner
Dryer won't start - only beeps
If this unit has a timer it could be faulty. Make sure with the schematic in hand that all the wires are in the right spots on the motor. I did not post the model number so I am not sure what model you have but looks like a Whirlpool part number. If motor was running before you attempted to remove blade, this is a good one. If the motor relay is clicking but not turning that is almost like power is not were it should be. You can contact me here or reply to FIXYA with a response. Click here to see posts on dryers. I wish I could be more help. The first place I would start is with a schematic.
Apr 30, 2013 | Dryers
Instal capacitor on Rudd 10Ajb24a01
Hi, this is a 2 ton unit from the numbers you have provided. I'm not sure what you are asking about the capacitor?? If you are installing the run capacitor, is it for the compressor/outdoor fan motor? I can't tell you how without looking at the schematics on the unit. Its pretty simple though. If you know its bad, you may have to purchase one online. You have to be a contractor in the hvac field to get one at a wholesale store. If its a dual run capacitor, it will have a c, fan, and herm stamped on top. This is for the compressor and outdoor fan motor. It will say something like this, ( 30mfdx5mfdx370 volts and so on. The 2 brown wires on the condenser fan motor will go one taped off and the other on the fan terminal if you are using a dual cap. If you are using a single 5 mfd or larger on a new motor, both brown wires will go to each side of cap. I will need more details if this is not what you need. Thanks
H,V,A.C. contractor
Ps, Send me more information on what you need?
Mar 19, 2012 | Heating & Cooling
Rudd Achiever series model RQNJ-AO42JK 000 mfg
Turn the thermostat as low as it will go and have someone stand out side, they should here the condensor fan and compressor come on at the same time. They are two distinctive sounds so you should
be able to tell if the compressor is running.
If nothing happens and you are skilled with electrical
you can turn power off and remove the electrical
cover to the outside unit. Restore power and carefully
push in the contactor, if the fan and compressor
starts you have a thermostat or low voltage problem.
If just the outdoor fan runs on any attempt, more than likely you need a new capacitor.
Jun 18, 2010 | Ruud Central System Air Conditioner
Rudd heatpump compressor runs outside fan dose
I don't think the fan on it' own crates the problem. Could you find out what should be and what actually is the flow through it. If you needed <!-- MOJAIZBA.COM LINK CODE START --> <a href="" title="Flow units converter page on - Convert flow units online. Use the calculator for making conversions from one flow unit measure into another flow-volume amount between; acre foot per: acre-ft/day, hour acre-ft/hr, year acre-ft/yr, bar/day barrel Oil per day, hour bar/hr, minute bar/min, second bar/sec flow, cubic centimeter per day cm3 / day, hour cu cm/h, minute cm3/min, second cm3/sec flow, cubic foot feet per day ft3/d, hour ft3 / hr, minute ft3/min, second cuft/sec, cubic inch per day in3/day, hour in3 / hr, cubic inch per minute, in3/sec, cubed meter per day m3/day, hour cu m/h, minute m3/min, second m3 / sec, cubic yard per day yd3/day, hour cu yd / h, yd3 / min, cu-yd/sec, gallon US gal/day, gal/h, gal/min, gal/s, gallon UK per day gal/d, gal/hr, gal/minute, gal/sec, hundred cubic feet foot per day 100 cu-ft/day, 100-ft3/hr, hundred cubic foot per minute flow 100ft3/min, 100 cubed ft/sec, kilogram per day - Petrol kg/day, hour Gasoline kg/h, kg/min, kg/s, liter per day l/day, l/hr, l/min, l/sec, milliliter per day ml/d, ml/h, ml/min, ml/sec flow, ounce US per day oz/d, oz/h, oz/min, oz/s, ounce UK per day oz/day, oz/hr, ounces/min, oz/sec, pound per day - Petrol flow lb/day, Gasoline lb/hr, lb/min, lb/sec. USA – Imperial UK and Metric SI system units of flow. Buy the JavaScript JS and HTML code for this web flow converter tool application for your website." target="_blank">flow units converter</a> <!-- MOJAIZBA.COM LINK CODE END --> for a unit you'are comfortable with here is one we use if it's necessary. Let me know that...
Mar 21, 2010 | Ruud Heating & Cooling
I have a Rheem model RRGG 05N37 JKR Serial # AYA4785 manufactured in 1993. I have to replace the fan limit switch. Is the Honeywell L4064B2210 Fan/Limit Control Switch the correct one?
Typically any fan limit switch will work as long as it is the same length as the old one and is in temperature range as well as covering the hole that the old ond came out of. it the screw holes do not line up, besure to put a screw into the exposed holes to prevent heated air from leaving the cabinet
Oct 21, 2009 | Heating & Cooling
I have a 1971 mobile home and it has a coleman gas furnace in it modle #8665D766. I can turn the thermastate up and the combustion fan comes right on but the igniter never ignites. The pilot lite is lit....
It sounds as if one of the sensors is not signaling correctly, If the combustion fan is on. What you need to due is turn things off for a minute to test your sensors. Start by looking at the emission sensors. This can be done by looking at the schematic and following the line of electrical flow to the main switch. I had this same problem on a home furnace and all I did was follow that line of flow and checked the sensors by disconnecting each to see which one showed either an open or closed circuit, when it was supposed to be just the opposite. (Usually its supposed to be open if no flame is present, so you might see a short) It was in fact the sensor in combo to the igniter fan. If you don’t have the schematic I would look to Colman. All these circuits are simple circuits and very little trouble shooting to resolve. The hardest part is finding the parts to fix it. Thus the internet and the need for a schematic if you can find one. Most heating and air-conditioning outlets wont sell you parts even if you have an engineering degree and don’t want do deal with a technicians BILL.
May 10, 2009 | Coleman Heating & Cooling
Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Sep 20, 2008 | Ruud UAMB Air Conditioner
Rudd gas pack schematic
Email me and I can send you the schematick
Richard (Rick) Drennan
Global HVAC Distributors
Field Support Representative / Instructor
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Cell (209)456-0513
May 06, 2008 | Ruud UAMB Air Conditioner
Ruud UAMB Air Conditioner Logo
152 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
