Question about Electrical Supplies
We have a Liftmaster Pro Formula 1 garage door opener. When we press button to close door it goes down 3/4 of the way then goes back up...one of the sensors is amber and the other is green
  • 3 Answers
If your lights are bright green and bright amber, and they stay lit even when the door reverses, your problem is the logic board. Unfortunately this model only has a 1 year warantee and the logic boards are almost the same price as the head unit. This is a common problem with this series, it is worth the money to upgrade to unit with a 3 or 5 year warantee. they are rediliy available from HD and others.
Posted on Sep 25, 2009
  • 33 Answers
It sounds like the sensors arent facing eachother and check the wires were they hook up to the opener
Posted on Jan 08, 2009
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a chamberlain liftmaster professional Formula 1 Garage door opener that has been working for 5 years. Now will not go down unless you hold the main button. Sensors blink when it hits within 3...
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. They each have a small light that should be lit, both should be the same brightness and not flickering ever so slightly. If not tweak them a bit. If both lights will not come on you have bad sensors.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I Have a Liftmaster Professional Formula 1 garage door opener. When we press button on wall or garage door opener, we hear the motor going but the garage door doesn't do anything. Do I need a new opener?
There is a rope or string hanging down that releases the dog that hooks the door to the chain...if someone pulled that the door will not open. You need to pull down and back on the srting to relaese the dog and then push the door up to catch the chain...then the door will work again...
heatman101
Aug 14, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a chamberlain liftmaster formula 1 garage door opener I could able to open the garage door using the remote. How ever I was not able to close it using the inside main panel big white color button....
Check to make sure the sensors in the doorway are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close from remote or car.
check the safety photocells is theres not obstacle between then, check both photecells leds are on.. otherwise no need to replace them
Mar 11, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Electrical Supplies Logo
461 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
