Could someone explain how I can adjust the sprayers to spray higher on the windshieldCould someone explain how I can adjust the sprayers to spray higher on the windshield
AnonymousMar 13, 2014
windows on passenger side stop working front and back 2005 pt cruiser convertablewindows on passenger side stop working front and back 2005 pt cruiser convertable
You can't post conmments that contain an email address.
Push the windshield wiper lever forward to spray washer fluid on the rear window. The lever returns to its starting position when released.
The windshield washer reservoir is used for the windshield and the rear window. Check the fluid level in the reservoir if either washer is not working.
Check fuse 1st.Then check and make sure motor is working for the windshield washer. If that does not work check line to be sure it is not broke or stopped up.
Stand by the washer reservoir under the hood while someone operates the washers. The headlights must be in the on position for the sprayer to work. Attached to the reservoir will be 2 washer pumps. On pump is for the windshield washer, the other for the headlight washer. They are interchangeable for testing. The reservoir can be removed after removing the 2 black speed nuts. (use a 10mm socket and ratchet). Also make sure the grommet with screen under each pump is not full green algae. Your pump has most likely failed.
the pump which is located on the outlet of the reservoir is either defective, corroded/loose electrical wiring on it or a blown fuse. Check the fuse first seeing it the easiest. Hope this helps
CHECK THE SUPPLY TUBES FROM THE PUMP TO THE SPRAY HEADS. SOME TIMES FINE PARTICALS OF DIRT WILL STOP THESE UP REMOVE THE HOSE FROM UNDER THE HOOD AND USE COMPRESSED AIR AND BLOW FROM THE SPRAY HEADS BACK TO THE OPEN HOSE TO CLEAN OUT THE DIRT IF THIS DOSN'T WORK LEAVE THE HOSE OFF AND TRY THE WASHER WITH OUT THEM HOOKED UP SEE WHAT KIND OF FLOW YOU GET FROM THE PUMP IF IT IS VERY LOW THE PUMP IS BAD
