Question about Archos AV 500 400-Hours Video Recorder
No input signal
Hi,i have a freeview digital box and when i connect my archos av500 to record from tv it says , no input signal in videocorder,i would be grateful for any help, thank-you.
  • KGodf_40 Apr 14, 2009
    i have the same problem with sky,i set it up and it says no imput signal.why does it say this.please help.
Ensure your tv is in av1 mode
Posted on Jun 21, 2007
Philips dvdr 3380
The dvdr3380 has an analogue tuner. It doesn't pick up digital TV.
Your TV picks up digital, but it isn't designed like a TV/cable box to be a signal source to an external device.
If you want to make TV recordings on to the dvdr3380, then you need to buy a TV tuner box (Freeview/Freesat etc) and connect that to your aerial system and to the line input of the dvdr3380.
Aug 18, 2014 | Televison & Video
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
I have an Alba 32880hdf freeview tv. I cannot record freeview programmes to my panasonic NV-FJ 780 vcr which has 2 scart sockets. I have no problem recording the teresteral channels. Can you help pls
Hi Victor,
You can't record the Freeview channels from the TV. It doesn't work that way. The reason you can still record terrestrial channels is because the VCR is still connected to your roof aerial with a co-axial cable and the VCR has its own built-in analogue tuner for recording terrestrial TV programmes.
To record the digital Freeview channels, you will either need to connect a separate Freeview set-top box to the VCR, or buy a VCR which has a built-in digital (DVB-T) tuner.
The VCR does not record programmes from the TV. It needs to be connected directly to the signal source, i.e. your aerial.
If you need any further assistance, please let me know.
Regards,
BElectric
Jan 15, 2011 | Televison & Video
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
Connecting my archos 405 30gb to my built in freeview tv
i can't record my TV,please help me Thank YOU mY eMAIL useryoh7784@telkom. net
Dec 16, 2008 | Archos 405 Digital Media Player
hi i found my own soulution for recording i will tell you an easy way fist of all you need another freeview box only connect this to your archos and have the other box connected like normal to your tv and place your archos and other box near your tv buy a 2 way splitter from wilkinsons and connect this where your ariel box is probably near the window and get another tv lead to reach your freeview box for the archos this means you have a connection running from the tv box for your normal tv and f box and another for the archos and f box cos of the 2 way splitter you can then record on the archos from the f box and watch another channel on your tv then playback later what you recorded of your archos on your big tv please let me know if you sort this and let me no if you get stuck its great when you get it all set up and it works thanks.
Nov 09, 2008 | Archos 405 Digital Media Player
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
How to record from DVR station
hi there, it should be easy, if your wanting to record off the tv/dvd or video you need to plug (lets say your using phono leads,the ends with red,white,yellow on them) into the output on the video (or what ever the device) the on the docking station plug them into input. then on the archos go to the videocorder n away you go. hope this has help`d
Feb 23, 2008 | Archos 604 Digital Media Player
Archos 504
Simply said you require a DVR station or Audio/Video travel cable. On the DVR just simply plug in your composite cable from OUT the satellite/cable box or whichever source your recording from to IN on the DVR station. The a/v travel cable is a little easier to hook up. Then just select the VideoCorder icon.
Aug 12, 2007 | Archos 504 500870 Digital Media Player
Archos AV 500 400-Hours Video Recorder Logo
226 people viewed this question
Top Archos Televison & Video Experts
Inky Fingers
Inky Fingers
Jaime Hernandez
Steve Sweetleaf
Steve Sweetleaf
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
