Question about Canon imageCLASS D880 All-In-One Laser Printer
WHEN I TRY AND MAKE COPIES THE COPY COMES OUT BLANK
WHAT DO YOU THINK THE PROBLEM IS, WHEN I TRY TO COPY SOMETHING IT COMES OUT BLANK? I TRIED TO UNPLUG IT AND THEN PLUG IT BACK IN, NOTHING THAT I'M DOING SEEMS TO WORK, HELP.
  • 77 Answers
Try checking the basics: Toner, lamp, and the other components, see if there is a jam.
Posted on Jan 06, 2009
Canon PIXMA MX300 Office All-In-One Printer and Fax MX 300 printing blank sheets
Do you have ink in the cartridges? Just because the computer says there is ink does not mean there really is ink.
Try making a copy and see if it copies. That will tell you if you have ink. Just go to the canon all in one and place something on it to copy and press copy from the controls panel on the printer.
May 31, 2012 | Office Equipment & Supplies
Making a simple copy comes out blank. color copies normal. changed black cartridge and still blank. faxes fine and prints from pc fine
Depending on your Operating System, you can try the fixes listed here.
Please keep me updated, we will proceed as soon as you try the fixes listed on the link.
Hope it works for you.
Sep 21, 2011 | HP OfficeJet K80 All-In-One InkJet Printer
Top load copies are blank
I tried changing the the size to a reduction. It took the sheet from the top and copied it at a reduced size with no problem. Then I switched back to normal size and it worked just fine. I would have never thought to try a different size without your suggestion. Thanks for the help
Randy
Jul 17, 2009 | Sharp Office Equipment & Supplies
Blank copies
see the cartridge do is good installed.
Remove the cartridge and putt it again.
If the problem do not go away please try with other cartridge.
Or if the printer is ink-jet printer and you have not used it for some time than the ink can be stuck
Jul 16, 2009 | Office Equipment & Supplies
PRINTED PAGES ARE BLANK AFTER REPLACING PHOTOCONDUCTOR
The machine should automatically recognize the new PCU. Blank copies would lead me to think you have further problems, charge corona? transfer issues? If you try to make a copy and open the front door real fast when the paper should be at the transfer unit, is there an toner image showing on the drum? If yes, then you have charge but not getting transfer. This is a hard problem to troubleshoot without seeing machine. Anyway good luck, please rate this. Thanks ..... Wait... just had a thought. On the shaft, on the inside of the rear frame, that drives the drum there is a coupling that is spring loaded. Sometimes the shaft gets gunked up and coupling does not pop out not connecting to the PCU, which could cause blank copies and will still say replace pcu. You could add a couple of drops of oil to that shaft to loosen it up if that's the case.
Jun 30, 2009 | Savin Office Equipment & Supplies
Error code F2-42
Are the lines horizontal or vertical? DO you get lines on B/W copies (black and white) also? If you try to copy a blank white page do you get the lines? Does the toner / lines wipe off after the copy comes out? If the toner wipes off after the copy comes out you have a problem in the fusing unit ( the hot area that fixes the image onto the page). If the lines are vertical then you have something inside the device that is dragging across the page as it goes through the device. If the lines are horizontal then you it could be the drum cleaning blade, the transport blade, or charge roller. The noise could be that one of the blades are bouncing. It could be that a gear is worn. Please give more info on the problem to better help.
Dec 31, 2008 | Sharp AR-BC260 Color Copier
WHEN I SCAN OR TRY TO PRINT A FILE THE COPY BUTTON IS ON.
From that, am I right to assume anything you print/copy comes out blank?
If it sounds normal otherwise, I would suggest trying to change the ink cartridges as they may be empty or dried up.
Dec 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon imageCLASS D880 All-In-One Laser Printer Logo
67 people viewed this question
old marine
old marine
