Question about Sony KP-61HS10 61" Rear Projection Television
KP-57HW40 Sony ..picture is blurry and gives me a headache also has a blue green tint and redish outline of the people???
  • Anonymous Jan 28, 2009
    I have same problem.....plus when you press info button from cable box remote..the words are blurry and have shadows.....my TV is about 7 yrs old. Can it be fixed for reasonable price...or should just replace?
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directiKP-57HW40 Sony ..picture is blurry and gives me a - 2c07611.pngnvergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6KP-57HW40 Sony ..picture is blurry and gives me a  - 2c07611.pngs=
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
    Scholar:
  • 87 Answers
You have bad convergence amps.
Posted on Jan 12, 2009
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Have Sony Model# KP-57HW40 Big screen rear projection tv..Has blue wavy lines across screen, and sometimes flashes blue, can you give me assistance??
Blue Picture Tube , bad Video IC on Blue CRT board.Or Blue screen drive control to tube needs to be adjusted down some.
Most Likely Bad Tube!
Jul 12, 2010 | Sony KP-57HW40 57" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
The screen is redish in color and the sound doesn't work!
This link has the instructions on how to fix this problem and other similar problems. You
have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection
TVs have the red, green, and blue pots in the same order as the picture that is listed on
this link, so you may want to google search for your model's service manual. The service
manual can also help you be able to remove the cover for your particular model of TV. I was
able to find the service manual for my model, and sure enough, the order of the pots are
reversed on mine, so I would have been adjusting the wrong color. Read all of the comments
on this link too, because you can find other helpful tips and may even find someone with the
same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
You can find information on Sony blink codes here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Blurry picture/adjust convergence
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C426085
I hope this helps you!
Fare well. :)
Iconoclast
P.S. You can also clean the mirrors and dry dust while you're in there which can help with blurriness and focus.
Jul 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP%&HW40 with varying background tinting
YOU HAVE 6 ADJUSTMENT BEHIDE THE SPEAKER SCREEN. THERE ARE TWO SCREWS YOU NEED TO REMOVE. ADJUST JUST THE MIDDLE BOTTOM SLOWLY. IT SHOULD CLEAR YOUR PICTURE. IF IT DOES NOT WORK IT MAYBE YOUR GREEN CRT. THIS TV IS GARBAGE. IM TRYING TO GET 100 PEOPLE CALL SONY APRIL 17,2008 AND GTHEN SEND TGHEM A LETTER AND AFTER CONTACT YOU LOCAL MEDIA FOR THIS DEFECT. SONY HAS TO PAY YOU BACK OR REPLACE THIS TV.
Feb 23, 2008 | Sony KP-57HW40 57" Rear Projection...
Blue tint screen in video mode
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP -57HW40 - Green Picture Tube - part new/used
CONTACT VIDEO DISPLAY AT 1-318-747-0140 AND TALK TO CHARLIE I GOT MY BLUE ONE FIX IN 6 DAYS!!! AMAZING FOR ONLY $152.00 THATS CHEAP YOU JUST HAVE TO SEND IN YOUR OLD ONE AND THEY REPAIR IT! AWESOME COMPANY!!!
Nov 27, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
