Question about Exercise & Fitness
PaceMaster ProSelect Error Code 31
Speed runs away.
    Top Expert:
  • 12,223 Answers
Mean defective lower PCA or upper PCA, try to tight any plug or connector or ribbon cable, However RUN the software calibration for easy troubleshooting , and fix it.
Go under the hood motor, and follow the step how to enter in the s. calibration.,see the block diagram attached.
God bless you
PaceMaster ProSelect Error Code 31 - 11_13_2012_3_34_34_pm.gif11_13_2012_3_35_37_pm.jpg
Posted on Nov 13, 2012
2 Suggested Answers
SOURCE: richelle07
was able to locate error codes from manufacturer.
Posted on Sep 10, 2009
How to adjust tension belt on pacemaster proselect treadmill
Tread Belt Tension Adjustment - Aerobics ProSelect ...
www.manualslib.com > ... > Treadmill > ProSelect > Owner's manual
Aerobics ProSelect Manual Online: Tread Belt Tension Adjustment. Step One:Locate ... Treadmill Aerobics PaceMaster Gold Elite Owner's Manual. Treadmill (38 ...
Aug 26, 2015 | Exercise & Fitness
Pacemaster treadmill err 133
I just fixed the same 133 error, it's about the communication between motor module and upper panel. There is an 8 wires cable, uses standard RJ45 connectors. In my case, one of the RJ45 connector to motor module is poorly done by the manufacture, so the connection is not reliable, I re-do the connector, problem fixed.
Apr 15, 2013 | Treadmill Doctor Pacemaster Platinum...
ERROR CODE 30 ON MY PACEMASTER PRO PLUS
DescriptionErrors 30 through 33 all indicate the loss of communications or erratic communications betweenthe microprocessors in the upper PCA and the lower PCA. The trouble shooting procedures forall of the are essentially the same. Error 30 is defined as upper PCA not receiving from lowerPCA. Error 31 is defined as faulty data received from lower PCA. Error 32 is defined as lowerPCA not receiving from upper PCA. Error 33 is defined as faulty data received from upper PCAPossible Causes1. An upper PCA to lower PCA interconnect cable is bad.2. The interconnect cable at the upper PCA was mistakenly plugged into the CSAFE connector.3. A 5.17 EFX equipped with version 1.01 upper and lower software.4. A 5.17 with mismatched upper and lower software.5. A defective lower PCA.6. A defective upper PCA.Possible Remedies1. Substitute a know good interconnect cable between the upper and lower PCAs to determineif the interconnect cable is defective.2. Remove the interconnect cable from the CSAFE connector and insert it in the correct upperPCA connector.3. Replace the 5.17 upper and lower software with the most current software versions.4. If only one of the upper or lower software is version 1.01, replace the version 1.01 softwarewith the most current version of software.5. Substitute a known good lower PCA to determine if the lower PCA is defective.6. Substitute a known good upper PCA determine if the upper PCAs defective.Proceed according and fix it. God bless you
Mar 23, 2013 | PaceMaster Aerobics Pro Plus Walking Belt
My treadmill no longer asks me for my weight, and I'd like to reset it.
go to reset. Turn off the power and reset the button too. Try again.
After that RUN the software calibration for easy diagnose, troubleshooting and fix it.
Happy New Year. God bless you
Jan 01, 2013 | PaceMaster ProSelect Treadmill Incline...
Treadmill no longer asks me for my weight, and I want to reset it.
try to turn off the machine. and reset the button and try again.
Happy New year. God bless you
Getting a dead sensor reading on pacemaster pro plus treadmill
OPEN MOTOR SHROUD INSPECT THE COMPARTMENT ON THIS INSTANT I BELIEVE THAT THE SENSOR IS AT THE OPPOSITE END OF THE MOTOR THE LEADS GO INTO MOTOR CONTROL BOARD I WOULD FIRST UNPLUG AND PLUG THE CONNECTOR THIS WOULD CLEAN ANY OXIDATION OFF. IF NOT YOU SHOULD BE ABLE TO DO THE REPAIR
Mar 02, 2010 | Exercise & Fitness
Exercise & Fitness Logo
1,268 people viewed this question
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
