Question about RCA DRC8052N DVD Recorder
Rca drc8052nb only says ''hello'' on screen, can anyone help?
The unit will not turn on. I've read that I should unplug it, so I did and then when I plug it back in it just says ''hello'' on the screen, but doesn't respond to any remotes presses, or button presses on the front.
  • 2 more comments
  • jpcnmt Jan 20, 2009
    I played a movie on this, and when it was over, I pressed open/close. The DVD came out and I removed it from the tray. Went to put another DVD in, and the tray closed by itself. When I tried to press the open button on the front , it just said open on the display. Unplugged the unit and waited. Plugged the unit back in and it would only read "Hello". Any help would be great Thanks.
  • riverratphil Jan 31, 2009
    Hello, I had the same problem and went to get it looked at. The shop told me the main control board was fried. We had to buy a new player. Look on local classified websites. I'm a big fan of Kijiji.com but that's in canada. Not sure if you're in canada, but u should check it out, We got a really nice recorder for $40.
  • Anonymous Feb 25, 2009
    I am having the same problem, but I was able to run a dvd off an external dvd drive I hooked up to the rca drc8052nb . So the motherboard cant be fried.
  • Anonymous Apr 13, 2009
    I have had this problem for a long time, and yes it had to be unplugged each time, then would work. This is obviously a manufacture's defect and we should be sent new equipment that works under the warranty, even if the warranty is expired. My board is not fried. I am a certified electonics technician and checked it.
    There was a similar problem with Epson printers and people were at least given a coupon for purchasing another item after a law suit.
  • 3 Answers
RCA DRC 8052NB does nothing but displays "HELLO"
Among the voltages available from the power supply is a 3-volt source. The first capacitor after the diode is a 1000 microfarad, 6.3-volt unit. There were no signs of leakage of overheating, but I changed it anyway. Voila! the unit came to life. Hope this helps.
Posted on Jul 12, 2009
  • tedeshafer
    tedeshafer Jul 18, 2012
    Also 2200 uf 6.3v on power supply broad use a 10v the dvd uses the ide hookup same as computers just buy one from a computer store and put it in try to get the same lenath
My friend has the same model and the same problem it says hello. When we held the power button  down the clock would come the screen. We work on electronic equipment for aliving. We traced the problem to the power supply board. You have to take the screws out to remove the cover. If you don't feel comfortable doing this find   someone who does. You also need to be able to remove componets from the aboard. The power supply is the smaller board to the right of the dvd tray. The capacitors brake down and lose some of the cap MFD value. The capacitor that went bad  was a 1000 MFD 6.3 volt. We replaced it with a voltage  thats higher then 6.3. You can check voltage with a volt meter. I think the votage numbers are on the board. Look on both sides of the connectors. Sorry we don't have the cap location number put they put it back together before I could get it.
If this helps some people let me hear it. E-Mail neveo1999@yahoo.com
Posted on May 29, 2009
  • 4 Answers
According to montilla (his link is dead) the solution is discussed in this thread: http://forums.afterdawn.com/thread_jump.cfm/143317/4227459
it says that the problem is caused by faulty capacitors C1260, C1270, and C1271 which can be burst or leaking.
here is photo http://i38.tinypic.com/nehn5e.jpg with these capacitors.
They can be subtituted by 1000uF 25V capacitors ( they are 680uF 16V)
These faulty capacitors can also cause problem with proper finalizing written discs.
Posted on Apr 09, 2009
I also had this same problem with my DRC8052NB. After a power outage it would no longer turn on and was stuck on "HELLO". Like neveo1999 and roybro123, I replaced the 1000uF, 6.3V capacitor (C22, which on mine also did not show any signs of bulging or leaking), and now it seems to be OK. The capacitor I replaced it with was 1000uF, 16V.
Before I replaced the capacitor, the 3.3V output was only in the 2.8V range. Now it's right up at 3.3V again. Thanks for the info!
Posted on Jul 25, 2010
Http://forums.afterdawn.com/thread_view.cfm/707232
This person has a very good guide on how to fix this issue. I've owned 2 different types of DVD recorders and the Capacitors used on both are ****.
These instructions are very easy to follow. GOOD LUCK
Posted on Jan 31, 2009
Hi, sorry for bothering I was recording a DVD-R with some videos but I pressed stop and was trying to move on but there was a red circle full filling itself over and over again it was 2 hours later when the light went off and the power switched off. Now I can't finalize the disc and my rcr192d1 asks me to erase the content. How can I finalize my DVD PLEASE HELP ME!
Posted on Jul 28, 2012
Hello...Have RCA L40FHD41YX9 ,serial number J203C40GV. Watching t.v., picture and sound go. Unplug, then replug...blue light in front, but still no picture or sound. Please advise
Fred, Unplug for a couple hours then try, if does not reset, board,capacitors or power supply gone bad.
Check the attached links for TV's problem.,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Fix Your TV Instantly
how to fix 42 RCA flat screen
RCA 276046 Power Supply Unit PSU Boards Replacement Guide for RCA LCD TV...
http://v6.tvrepairtips.org/anon/supertips?page=1&make=&model=LTV46W1%20HD&problem=
Mar 07, 2016 | RCA Televison & Video
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
My dvd player model: DRC8052NB is stuck at the hello,hello in the screen and it wont play any dvds
your having problem with the hardware..... others are caused by excessive heat inside and need a proper ventilation and if symptoms persist consult a technician to check your device.
Jul 12, 2011 | RCA Computers & Internet
Dvd will not eject. tray will not open. pressing open causes "hello hello". is there a way to manually force the tray to open without damaging the dvd?
The DRC8052N / DRC8052NB / DRC8052NC DVD recorder (sorry cab209, not a PC) has had a LOT of problems. So many that RCA doesn't even list it on their site! There was a firmware upgrade that supposedly fixed this, but I'm having trouble finding it on the web.
As to how to remove DVD:
1) Try unplugging the machine and leaving it unplugged for 10 to 15 minutes. then (without plugging it back in) press the power button repeatedly. (I know it sounds goofy but it came from customer support. Theory: to drain all power) Plug it back in and try to eject.
2) Another owner suggested holding down the HDMI button on the remote. The "hello" mesage is an initialization/power-on routine, so my guess would be it was powered off with the disc in it?
3) Unplug it. Remove the cover (two silver screws on each side and three black screws on the back). Slide the cover off (to the rear). Take the four small screws out of the top of the drive (marked LOADER on mine. Lift out the DVD. Reassemble.
While you have it apart..... You might also look at the circuit board next to the drive in the center of the unit. It has a bunch of capacitors (black or blue, cylindrical, w/ X or Y stamped in the end). If any of these are no longer flat on the X or Y end or have yellow 'goo' on or around them, they have failed and are the source of your problem. They can be replaced, but it may be more cost effective to replace the entire unit.
Jim
Jan 02, 2010 | RCA DRC8052N DVD Recorder
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
RCA DRC8312 DVD/VCR player is stuck on Hello
Faulty power-supply symptoms:
The front panel display and buttons are completely nonfunctional and appear dead. The unit will do nothing more than display the following messages on the TV screen:
Interface error
(and or)
Interface error! Turn off the power
If a DVD or VHS tape was inserted prior to the error occurring, you won't be able to eject either from that point further. They'll remain stuck inside the unit until you've completed the repair detailed below.
Interface error! Turn off the power <--- explains how to completely restore your combo in less than 20 minutes by replacing a $1.59 part on the power-supply board. mikeadams110@yahoo.com
Nov 13, 2008 | RCA DRC8335
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Our RCA model #DRC8335 VHS/DVD recorder is not working. I had a disc in the machine, but not watching. My son turned the cable on and instead of showing AV1 it showed "Reading" on the screen of...
watch out if you contact rca/thompsen because they had me sent my unit back that went defective. I wanted over a month and never heard anything back...and now find out they don't have this unit available for replacement. they have no clue when they will and only can offer a refund of 134.37 which is about 50 bucks less than I paid for unit at walmart....RCA/Thompsen is a ripoff
Aug 29, 2008 | Televison & Video
DRC8052NB DVD PLAYER WONT TURN ON
New? return it to where you purchased it.
Sep 17, 2007 | RCA DRC8052N DVD Recorder
RCA DRC8052N DVD Recorder Logo
5,014 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
