Question about GE Spacemaker JVM1640SJ Microwave Oven
The bottom of the door handle broke off. GE spacemaker xl
How to fix or replace door handle that broke off...the bottom half of the handle is off. GE spacemaker xl jvm1339
  • GE Master
  • 9,086 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 09, 2009
You actually don't need to remove the door panels as stated in the prior post. Instead there is a plastic trim piece on the inside of the door that needs to be removed to access the lower handle screw. The trim piece I'm referring to is about 1/2" wide and runs around the entire inside of the door. It is easily pried off with a small screw driver.
Instead of ordering a new handle I simply used a longer screw to reattach the broken handle. You will need to drill out the original screw hole making it deeper so it can accommodate the longer screw and prevent the plastic from cracking.
Since I had already removed the door panels as recommended in the prior post, I decided to add a second screw next to the original one to further strengthen the handle where it attaches at the bottom of the door. I drilled a small hole through the plastic door panel that was removed from the door. There is not much space next to the original hole so I had to use a shorter screw with a fairly small head to fit in small area. After you drill a hole in the door panel hold the handle in place and drill a small hole in the door handle to receive the second screw. Be careful not to over tighten the screws when reattaching the handle so you don't strip out the plastic holes.
The repaired handle is now stronger than the original handle and should not come loose again.
I hope this helps - Scott.
Posted on Oct 21, 2011
The door handle on my GE spacemaker xl 1400 microwave is broken (plastic). How do I fix this.
By replacing with new one for sure... You can find them on amazon, here: Amazon com ge spacemaker xl handle. I hope this was helpful. Cheers
Nov 14, 2010 | GE Spacemaker JVM1740 Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a spacemaker XL GE microwave and today the bottom part of the handle cracker and broke off. Can I get a new handle?
yes / very common problem . you can order from g e on line for most parts supply 's / appliance parts depot. on line . . hope this helped mm feed back pls ..
Dec 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to Replace Spacemaker XL door
i'm also looking for an answer.
Thanks
Mar 15, 2008 | Microwave Ovens
How do you replace a broken handle for a GE Spacemaker II microwave?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
On some models, the handle may rotate into and unlocked position then lift out.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,808 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
