My uncle just gave my son a g-100 amp. it is a old tube amp made by yamaha . it has a lot of scratchy niose. the amp works. someone said it might need to be cleaned. do you think that will work?. if so what do you clean it with?
    Scholar:
  • 58 Answers
The g-100 is a solid state amp produced by Yamaha in the late 1970s.  If the "scratchy noise" is produced when turning the knobs, it can be cleaned by using a spray called "de-ox it" or an electronic contact cleaner and lubricant like CRC-56.  The best way to clean old rotary potentiometers (the electronic part of the knobs) is a good hard turning.  Moving the knob back and forth with firm gentle pressure can actually clean off residue and result in a cleaner tone.  Try to apply the cleaning spray to the knob stem only and to no other surfaces.  Another great electronics cleaner/spray is Contact ReNu made by MillerStephenson. If the problem persists you might want to take this amp to a pro repair guy. Good Luck!
Posted on Jan 06, 2009
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
92 Yamaha over heating make rumbling niose then
Sounds like you need an experienced motor mechanic
Aug 18, 2013 | Yamaha Boating
My son plays these full blast and looks like he blew a speaker (scratchy). can they be repaired?
If you can get the part and fit it yourself it probably can be repaired.
In terms of getting someone to look and repair it for you its not worth getting them looked at. Be cheaper to get a new one.
http://www.google.co.uk/products/catalog?client=safari&rls=en&q=Bose+Companion+2+Series+II&oe=UTF-8&redir_esc=&um=1&ie=UTF-8&cid=15319379603275211428&sa=X&ei=OcK1Tfv5FMao8AOf8JjRAQ&ved=0CEQQ8wIwAg#ps-sellers
Apr 25, 2011 | Bose Companion 2 Series II Multimedia...
Bought amp 1 year ago, three months ago, no sound, Guitar Center said call an authorized repair shop. I did'n't open it up to check fuse because i didn't want to void the warranty. The shop replaced the...
Possible that the output tubes that were replaced are drawing too much current, hence the popping sound (may be "motorboating", one common word to describe a similar sound)
This means the tubes need to be biased properly. You need to get it to someone who knows what they are doing, ie a good amp tech, not GC. The voltages here are dangerous.
Feb 25, 2011 | Marshall JVM410C 100 Watts Valve Guitar...
We have a philips 52" projection tv that my son
If it has a blue cast someone likley turned up the blue brightness inside the TV...there are 6 knobs...2 for each color..try turning that down. Its not the PIP or bad tube...
Jan 06, 2011 | Philips Magnavox 51MP392H Rear Projection...
My uncle gave me his old sgh-1607 but requires a password the thing is his son put the password and he does not what it is...what do I do?
the passworkd is usually the last four of the phone number, 0000, 1234, or 12345. If he changed it, there is o way to reset it.
Mar 29, 2010 | Samsung Blackjack SGH-I607 Smartphone
Scratchy intermittant noise on warm up
Hi, how old id the amp?
Have you tried re-seating the valves? Give this a try.
It could be a multitude of things, Solder Joints, Leaking / Bulging capacitors, Dried Out Capacitors, Faulty Valves.
It could be that the valve might be on there way out.
Which amp do you have?
I can't really offer anything more, but if you have more questions, then please ask.
Regards - Anthony
Feb 26, 2010 | Audio Players & Recorders
It was dying it made a niose like a clapping as i gave it more gas the louder it got and started to go slower. efi 4cy 242,356 miles
I would check http://www.car-parts.com it is a web site that queries salvage yards on line and will sort by price or distance, you can look by the entire US or by state. Page with * next to it shows the lowest price. Hope this helps
May 22, 2009 | 1988 Toyota Pickup
A lot of gas coming out of the carb. overflow tube, eng on or off
the float pin is stuck or has some dirt in it. try tapping the side of the float bowl(s) with the handle of a screwdriver... not hard enough to break it. if that doesn't work you will likely have to take the carb apart and clean it.
Apr 06, 2009 | Yamaha YZ 125 Motorcycles
 Grubhead
Grubhead
