Question about Whirlpool 24 in. DU1055XTP Built-in Dishwasher
Our porwer went out on the block just after dishwasher was started when power came back on the clean light is flashing and all book says is to check heater ciruit. What do i look for and how do i check it thanks
  • 3 more comments
  • Anonymous Nov 02, 2007
    We had this same problem and your solution worked perfectly. We have a Whirlpool Quiet Partner dishwasher.
    Thanks!!!
  • MBlank Apr 07, 2008
    Another success story. Thanks for the great tip!
  • Anonymous Feb 28, 2009
    The reset sequence worked great for my 7 flashing clean light, don't know how you came by that trick, but awesome, thanks.
  • mgtd Mar 14, 2009
    I have the same problem. Reset, as above, goes through check and then cycles, but has been getting worse in that is goes into this "Clean Light Flashing" mode more frequently.
  • Anonymous Mar 18, 2014
    NO PORWER AND NO LIGHT FLASHING
I don't know if your dishwasher is the same as mine, but this solution may be what you need. For electronic panel dishwashers made by whirlpool (mine is a whirlpool but with a kenmore name on it), some of them can be reset by pushing in sequence the Heated-Dry button followed by the Normal-Wash button, several times in a row. that is... Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up. When all lights light up you can stop. The washer will then take 5-10 minutes to go through a diagnostics cycle, which is about 18-25 steps or so. You can bypass one step at a time by pushing the STart button. This may not apply to your washer, but is pure gold if it does. Good Luck!
Posted on Aug 18, 2007
  • Mathieu Schneider Feb 17, 2012
    Worked for my Whirlpool GU2300XTSQ0. Thank you! Thank you!
Saved me a service call! Very helpful. Thank you thank you. Free icecream from the wife too.
Posted on May 20, 2008
Thanks
Did the trick
Posted on Nov 25, 2007
I have a whirl pool GU2548XTPQ3 having the same problem, not sure about the power outage.   Push Heated-Dry, then Normal-Wash, Then Heated-Dry, then Normal-Wash... Repeat until all lights light up to reset the unit worked great for me
Posted on Oct 16, 2007
Clean light flashes when cycle is interrupted. Push clean button again, or cancel wash and restart.
Posted on May 27, 2007
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
The clean light is flashing on a whirlpool dishwasher-model du1048. The manuel says the dishwasher has malfunctioned and to check the heater circuit. How do I do that?
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Feb 17, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
My dishwasher is leaving a thick flaky residue on all my dishes and we use a rinse agent on nearly the max setting. The Heating element doesn't work.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jul 26, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
The clean light stays on all the time
if it flashes 7 times its not getting hot water. if it is you need to change yur heater. it comes as a kit with a board
Feb 12, 2010 | Whirlpool 24 in. DU1055XTP Built-in...
Just installed a whirlpool dishwasher du1055xtpq0. when trying to start it the start light just flashes
Sounds like the door isn't latching properly,sometimes this can be from not being level,the tub can torque to one side and the latch doesn't line up correctly.
Aug 22, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
THE CLEAN BUTTON KEEPS BLINKING AND IT WANT ALLOW ME TO WASH DISHES
Take bottom panel off will find service sheet will tell you what to do.
Jun 16, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool DU1055XTP dishwasher fills with water but won't wash.
Can you be more specific? Does the dishwasher fill and then overflow?
Apr 11, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool gu2400 dishwasher
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Dec 05, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Whirlpool 24 in. DU1055XTP Built-in Dishwasher Logo
978 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
