Question about Whirlpool Duet GHW9150P Front Load Washer
Flashing codes my whirlpool duet washer is flashing a F then a dl. what does this mean
  • Leigh Clark
    Leigh Clark Feb 13, 2009
    i hear the click click trying to start the washer but codes read dl and f3. where do i start to get a circuit board or what do i do. i cannot afford a repairman but my husband is electrical savvy. thanks so much leigh
  • 530 Answers
You have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Posted on Jan 07, 2009
Error code F71
Posted on Feb 06, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
"F11" is a serial communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU), or interconnecting wiring. In a nutshell, the CCU, (which is the main computer board for the washer) has more than likely failed. You can try disconnecting the connectors and plugging them back in on the CCU, but I haven't had much luck with that remedy. You will need to UNPLUG the washer & take the washer top off by removing the three screws in the back to gain access to it. Once removed, slide the top back and then lift up. The CCU is located directly behind the wash tub.
If you cannot get the fault to clear and wish to repair this yourself, you can find the part at repairclinic.com. Just type in your complete model number and look for item number 1176592. The part lists for about $157. Searspartsdirect.com also has the part for much more, but offers informative troubleshooting diagrams. The CCU can be found under the "Control Panel Parts" heading as item number 15 (part #8182695). If you wish to do some comparative pricing of your own, use the part number provided by the Sears website.
If the washer still carries a warranty, this would be covered. Doublecheck with the manufacturer on how long some parts are covered. Some of the electronics and mechanical parts are covered beyond the one-year limited warranty that generally comes with your appliance.
I know this may be discouraging news, but you can repair this yourself and avoid labor costs. It may seem expensive, but considering how much these washers cost (I know, because I own one), it may be worth the effort. I hope this helps you. Post back if you have further questions or need instructions.
Posted on May 08, 2008
  • 171 Answers
SOURCE: whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 11, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 220 Answers
SOURCE: What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Posted on Sep 13, 2009
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Duet frontloader, washer won't start dL
Hi
Thanks for using FixYa. Error "dlf" or F dl means a door latch failure. This means that you'll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it's unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 18, 2010
Testimonial: "Thanks, noticing the latch did not click I just pushed on the handle and jiggled it and it came on... so it must be going out. Thanks for your time"
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F11 and/or dl code on a whirlpool duet front load washer
F11 is:
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check for:
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check the Drive system for any worn or failed components
Check MCU
Check CCU
Check Motor
Check Wire Harness
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
Check the above link for a detailed article about the f11 error code.
Courtesy:JSrock
Apr 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet washer code
Hi Keitha1
Thank you,
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool washer duet--- the display is flashing f-dl and won't start it sounds like it wants to do something but won't.
"Fdl" is a door latch error code. Typically this means the latch requires replacement. The following link will explain this and tell you how to replace it.
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
You can find a replacement door latch at searspartsdirect.com. Just type in your complete model number and follow the link headings on the following page. If you need assistance with identifying the correct part, let me know what you rmodel number is and I can assist you. I hope this helps you.
Aug 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
992 people viewed this question
Dan Webster
Dan Webster
prem mathew
