Question about SanDisk Sansa m230 MP3 Player
My SanDisk Sansa m230 will not turn on at all
I've had this MP3 for a few years and now it will not turn on, even when I place fresh batteries in it. What I would like to know is if there is some way I could fix this at home, or if it would be wise just to buy a new one?
  • Anonymous Mar 08, 2009
    Same here
  • Anonymous Mar 16, 2009
    Exactly the same here, and it makes me frustrated because sometimes if I try it will turn on, but most times it won't.
Try to reset it by holding in the start button for 15 seconds.
Posted on Mar 20, 2009
My sansa mp3 only begins to turn on when i connect it to the pc but then freezes when it says 'Sansa m250 2.0 Gb' please help
Look further than the batteries. Take the whole thing apart. That's what I do, and I've fixed a lot of things. And keep looking on the internet. A few hours of looking can result in years of listening.
Jun 16, 2012 | SanDisk Sansa m230 MP3 Player
My son can't get his sansa mp3 player to turn on.
Try this:
1.First, remove the battery. Then press and hold the "Menu" button for 30 seconds. This would cause the excess static electricity to be discharged from the player.
Insert a fresh battery and try to power it on. If it still doesn't power on, try the procedure again, but this time, press and hold the "Menu" button for 1 minute. Insert a fresh battery again and see if it would work.
2.
Plug your player in your computer and your Operating system should recognize it as a "Removable Disk" and it will have a drive letter. Right click on the M230 drive letter and select "Format". When the Format window appears, just make sure to set the File System type to "FAT" and make sure that the "Quick Format" option on the bottom section of the window remains un-checked. Click start to format the player. Follow the on-screen prompts.
3.
Use this link from the SanDisk website to download the Sansa Firmware updater:
http://kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
Mar 07, 2011 | SanDisk Sansa m230 MP3 Player
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
SANSA won't turn on.
replacing the battery may be a possible solution.... if that doesnt work,try sliding the hold switch to on position and then connecting.
Sep 01, 2009 | SanDisk Sansa m230 MP3 Player
Will not turn on
Your question is sort of incomplete. It could be a few things. dead battery, damaged battery, corrupt system file(s), missing system file(s) or maybe it has water damage. it could just be old anyway GOOD LUCK
Aug 18, 2009 | SanDisk Sansa m230 MP3 Player
Reseting my sansa m230 mp3 player
You can reset the player by removing/reinserting your battery.
Here is alink to your user's manual:
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_Eng_m200.pdf
-Tha Mp3 doctor
Mar 16, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230 will not come on
SanDisk Sansa m230 (512 MB) how can i do when my sansa mp3only says iitializing udates... MP3 Player
Jan 21, 2009 | SanDisk Sansa m230 MP3 Player
M230
Try deleting files to get at least 4mb of free space. Unplug any speakers or headpones (some speakers cause it to shut down when played at higher volume levels, probably due to impedence incompatibilities). Make certain you have an absolutely fresh battery in it. When it comes on after being connected to a usb port or after a battery has been replaced it uses probably more battery energy during its database initialization than at any other time. Even if the battery meter reads full, the draw might be more than a used battery can deliver. Once it does show you the regular song screen shut it down so it can save the initialization results.
Nov 06, 2007 | SanDisk Sansa m230 MP3 Player
Sansa m230-just repeats startup message and wont continue
get a new MP3 player it is garbage there are somethings you can fix and that my friend is not one of them :D ~Grim
Jan 10, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
225 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
