Question about Toshiba 50HX70 50" Rear Projection Television
No video, Blown fuse f470, audio works great.
My Toshiba 50HX70 has no video, I can change channels and hear the audio fine. Picture was fine before it died, no convergwnce problems. Fuse F470 is blown but when crossed with another fuse there is still no video. I have the power/def board out on my bench now. Any help would be great. Thanks Steve
    Problem Solver:
  • 6 Answers
I replace same fuse. then found that if there is no viedo feed the tubes turn off. so make sure you have a video feed after putting in the new fuse.
Posted on Jan 22, 2009
  • 143 Answers
Check your h uot transistorthen check pico fuses
Posted on Nov 03, 2007
The left channel works correctly on both A and B. The right channel does not work on A or B. It's not a source problem as it does it with all sources. Tape monitor is not on. You can very faintly...
a blown channel or maybe a fuse.more likely the channel.it will have to get repaired by a technition.i had the same problem. one side works well and the other side only just hear a little sound and may be crackly
Oct 17, 2010 | Audio Players & Recorders
My Toshiba TheaterView has no sound or picture
You may have overloaded your audio output with the external speakers(impedance or short wire problem?)as a result the audio out i.c maybe damaged which in turn may have blown one of several fuses in the power supply.maybe regular GMA type fuse or picofuses,you can try replacing blown fuse but if they blow right back you`ll need the help of a repairman
Nov 02, 2009 | Televison & Video
I have sound and no picture
These unit will mute the video for a number of reasons. F889, F890, F891, F850, F470 one of these fuses is open then fine out what caused the fuse to open. This an older unit so parts may be hard to find. The cost to repair it should not be to bad.
May 14, 2009 | Televison & Video
Toshiba 50hx70 sound but no picture
NORMALY SOUND BUT NO PICTURE IS THE LAMP YOU SHOULD CHECK THAT TO SEE IF ITS BLOWN
Mar 07, 2009 | Toshiba 50HX70 50" Rear Projection...
My video in jack will not work?
I had to goto setup and change the setting from s-video to video
Feb 18, 2009 | Toshiba DRW2 DVD Recorder
Toshiba 50H72 problem plz help!
ok well both of you have had the same problem i did... to fix the picture problem check the circuit board pd0074 its the yellowish looking one next to the green one which has the ic's on them... ok on the pd0074 board look for fuses f470, f850, and the f851 to see if they are blown the f470 is what turns the tv on and the f850 and f851 are what protect the convergence ic's chances are they are blown.... the sound i don't know how to fix that problem but i would check all the fuses on that board to find out if one more is blown that what i did but the only thing is that i could get the actually fuses for the tv i was told by a tv repairman in my town to just take 2 wires sodder them on to the fuse and take a glass fuse and put electrical tape around them and it worked like a charm... so i hope this helps you.... the most i spent was 30 dollars for the ic's and the fuses all together and i was quoted at 450 to do what i did myself
Oct 31, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H82 blown fuse f470
Solder jumper wires for prevent maintenance.....on signal
board = 008,010,017,048,600.............................T.
Oct 23, 2007 | Toshiba 50H82 50" Rear Projection...
VOLUME
Check first to see if n menu speaker are off or then you may have to change audio amp IC. in 7700 location before changing look for blown round black fuse 2A 250V, 1700's
Aug 07, 2007 | Philips 60PP9202 60" Rear Projection...
Tv repair
This happened to mine. It was a fuse that cost $3.42 but the service call was $200! If I knew how to do the freaking work I'd be rich!
Apr 09, 2007 | Toshiba 50HX70 50" Rear Projection...
Toshiba 50HX70 50" Rear Projection Television Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
