Question about Refrigerators
The freezer part works fine but the cold is not being transfered to the main part of the fridge.
  • rodtindall19 Jan 06, 2009
    Haier frig, model HTF 18GAARVS: freezer works OK but not the main part of the frig
  • rodtindall19 Jan 07, 2009
    It seems so.
  • 679 Answers
There is some problem with the air flow; check fan and also check vacume rubber.
Posted on Jan 06, 2009
  • rockfixya
    rockfixya Jan 07, 2009
    please let me know if any of the given solution works for u.
    Thanks for using FixYa.
    Scholar:
  • 86 Answers
Tubes or pipes must have been broken. You need to check for leaks on freon gas as well as this is the main element that acts as coolant for the fridge,
I would suggest that you bring it to your nearest service center since any leaks could also be harmful to health and environment.
Thanks.
  • 66 Answers
Sounds like exchange fan is not working
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
To check:
  • fan - open the door, locate the door switch, press on it, light should go off, fan should kick in within 60 seconds. If not, faulty fan, fan relay, or controller. Alternately, you can measure the continuity of the motor's coil and or if there is voltage going to the terminals of the motor;
  • thermostat refrigerator side, you would need to use a continuity tester or have an electronics shop perform this. At room temperature the reading should be low, and should go high when the probe end is submerged in a glass of cold water.
Alternately, it may be the vents, flaps or vanes that are stuck, clogged, blocked and hence no air flow from the freezer to the fridge side.
Good luck and Thank you for using FixYa.
  • 10,515 Answers
Check if the fan inside the freezer works. It should be "on' at the same time when the compressor is running.
Check if there is frost on the back panel in the freezer.............
********waitning for reply****************
    Sergeant:
    Scholar:
  • 199 Answers
The air vent tube may be clogged.to resolve this defrost it completely for a day.and it will work properly after that.
    Sergeant:
    Champion:
  • 304 Answers
What is the exact model of the fridge.
check and inspect any possible leak or problem on the door, it can be not tightly close
Kelvinator cyclic 410 Upside Down Fridge Freezer. Fridge not getting cold. Freezer is working fine.
Is the fan in freezer compartment working? Is the damper fully open to allow cold freezer air into fridge section?
Sep 23, 2017 | Refrigerators
GE monogram zis420d refrigerator is not very cold, but the freezer is fine
Usually the air transfers from the freezer to the fridge in the center of the back of the fridge and freezer areas. they are easy to identify, make sure the vents in both the freezer and fridge are not air flow blocked preventing cooler air from transferring to the fridge.
Sep 18, 2014 | Refrigerators
Kenmore fridge, model 253.63754302 freezer working fine, main fridge not cooling much (approx 62 degrees F.) Have been away for 7 months. Usually plug it in to restart and all works fine. Not this...
Your refrigerator is made by frigidaire it sounds like your damper is opening up if your freezer cold and the fresh food compartment isn't.
Nov 03, 2013 | Kenmore Refrigerators
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
Fridge is not getting cold
mine is the same. Top freezer works fine. Frig won't get cold but runs.
Apr 12, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer fan not working
Peace Friend,
ngfam1 At your service!
Ready?
If the freezer is cold and not the fridge, you need to make sure the freezer is filled to the top and covering the cod air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered whit packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
