Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer
My washer will cut off with 7 minutes left like it is finished it will not spin out the clothes i have replaced the control board and the drain pump it still will not spin I am at my witts end can you help please?
It will drain then start the slow tumble and then just cut off.
  • 1 more comment
  • terrywinfrey Jan 07, 2009
    yes it will tumble back and forward then cut off without spinning
  • terrywinfrey Jan 08, 2009
    I have already replaced the motor control board and the drain pump that did not solve the problem
  • onthethejob1
    onthethejob1 May 11, 2010
    will your unit tumble back and forward but not spin...
  • 640 Answers
You have a defective motor control board
Posted on Jan 08, 2009
  • 41 Answers
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
  • Chris Goulet Jul 25, 2009
    If your bad wax motor is a 0.05A rating, replace it with a 99001807. It should measure about 1.5K ohms.
    If your bad wax motor is a 0.12A rating, replace it with a 12002535. It should measure about 1.0K ohms.
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
GLTF2940ES will not spin. It enters the spin cycle, will spin lazily left to right, right to left, trying to balance the clothes, and then when it hits the 6minute mark it cuts to off.
Hi Samuel, thank you for allowing me to assist you!
Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Best regards!
Oct 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
Front load washer, try to spin, but stops altogether and want wash it fills up but want wash
Make sure that you don't over load the washer. As it starts to spin back and forth it is sensing the load balance as the clothes fall back and forth. If it doesn't sense a balanced load because the clothes can't fall back and forth it will not start the wash process. Refuse your load and try again.
Oct 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
Cycle is stopping at 7 minutes and not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
possible but i would look into the lock/latch assy being bad, if it doesnt think the door is closed it will not spin, nad there a re a feew different switcvhes within the latch to fail( would ve be my first choice and the part i have the most problems with)
Mar 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
866 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
