Won't deline, dont know much about it other than it wont decline.
SOURCE: Trying to fix a 20+ yr.old treadmill (Precor USA
Dear Sir:
I hope you are very well, in union with your family.
Thank you by your request, and I will help you inmediately.
Please follow the next step with very carefully:
Makesure that the surge protector being used is properly grounded(Very Important) and turned on.Check that the treadmill power cord is properly plugged into the surgeprotector.
Checkto see that the key is inserted in the console.
Checkthe circuit breaker on the frame near the power cord. If the reset/off circuitbreaker has tripped, wait 5 minutes and then reset the breaker by pressing theswitch in.
4)Check the circuit braker panel house, and reset.
Static Shock Problems:
Many people face a conundrum when using a treadmill. The problem is that a treadmill has you walk or run in a motion that causes you to build up an electrical charge on your body while you are exercising.
The problem if you are swinging your arms, you are totally isolated from any common ground so the charge just builds and builds and many discharges have been measured above 30,000 volts.
You may say, how in a frost-covered hell can I build up 30,000 volts on my body without killing myself? Good question and it has a good
answer...there is very little amperage. It will pop you good when you do ground and sting but it won't hurt you.
The problem is that it can damage the treadmill's electronics if it is not properly designed and we still see poor designs in this respect
If you don't like getting popped or if your treadmill is shutting down or going crazy, there is a fix. You can ground yourself to keep the electricity from building up on your body.
We now have wrist grounding straps that can be reused and attach to the frame of the treadmill without causing any markings and do not require any permanent modification to your treadmill. You can find them in any online catalog by electronic sales by searching for Grounding Strap.
Thank in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: golds gym trainer 480 treadmill stays at full
Dear Sir: I will try to help you, you must use some basic tools: screwdriver, Hex, Dvom(DigitalVoltemeter): http://www.youtube.com/watch?v=MIIxoPtvhy8 http://www.youtube.com/watch?v=M7qJrRbdfBc http://www.youtube.com/watch?v=Uzf4az4RRDE http://www.youtube.com/watch?v=9G4MZh8JO2Q This will be fix it. In another machines: You will follow the next: Any board control for elevation motor has 2 LED : DN= Down +UP= UP for Elevation Motor, when you push the button for Down the LED Yellow or Green DN, will be going Down Lit, and Viceversa. The Relais in this case 2 relais, will be operated by 12 VDC, you must Clean The Contact, with Special Solvent . You can buy from Radio Schack. Check the Fuse with Dvom, and Finally after you must check this, and the motor is Not O.k is Faulty. Replace. But check before any Wire loose, before to concluded that the Motor is Bad. If you need further assistance, you can reach me, sincerely God bless you. E.CUADRA MANAGUA, NICARAGUA. C.A.
SOURCE: My treadmill is stuck on
Wacht this videos+Tip:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
SOURCE: Treadmill won't start. Console works but when
If the console takes
batteries, replace them. If this does not work or your console does not require
batteries, check the reed switch or optic sensor. Reed Switch:
Unplug the treadmill and remove the motor hood cover. The reed switch is mounted
on the frame next to the front roller pulley. There is a magnet glued into the
front roller pulley. When adjusting the reed switch, make sure it is pointing
directly at the magnet. Move the tip of the reed switch within 1/8" of the
magnet. Also, check to see that the wire is not damaged, and is connected to
the console
Optic Sensor: Unplug the treadmill and remove the motor hood
cover. The optic disk and sensor are located either at the end of the motor or
the right hand side of the front roller. The optic disk spins between two
sensors on the optic switch. The disk must spin freely without touching either
sensor. The sensors can be moved by loosening the adjustment bolt holding the
switch to its bracket. The switch can then be slid. Center the disk.
Remember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
SOURCE: I can't fold my treadmill
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
