Leaking washing machine
Hi we have a zanussi zwf1621 washing machine and just lately (about the last 4 weeks) it has been leaking water onto the carpet at the front of the machine. I have pulled it out from the wall and the floor underneath at the back was/is dry. I have checked the filter thingy in the lower right corner and it clean and clear of any blockage. Any ideas as to where the leak might be and how i repair it please?
    Scholar:
  • 160 Answers
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Jan 06, 2009
Washing Machine leak underneath the machine - Zanussi FLS-579C
have checked the door seal
send the 91------------- no this is on a label in the door
Feb 05, 2014 | Zanussi Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
I have water leaking onto the floor from my LG Tromm washing machine. I tried to check for blockage of the hose but it is still leaking.
Check the connections on the back of the washer for the cold & hot water connections. This just happen to me last week. My husband tighten them and resolved the problem. Good Luck !
Jan 16, 2011 | LG WM-2277HW Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Burning smell and loose drum
If it is really noisey when it spins then this can only mean one thing.... the drum bearing are shot, its a complete strip down job, not an easy job for a beginer. Sorry
Dec 23, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi washing machine.
switch off
remove plastic clamp that holds seal to cabinet and peel seal off cabinet.
the inside of the seal is held onto the tub with a circular spring. push seal down (needs a bit of force), pull outwards and seal will come away from tub.
lubricate the slot in the seal that fits onto the rim of the tub with washing up fluid.
starting at the top, push the first little bit of the slot in the seal onto the rim of the tub.#
working in both directions, push the slot onto the rim until completely on. this is a knack so be patient.
the circular spring fits into a slot on the outside of the seal. this is quite difficult to get into place and extra pair of hands will help.
fit seal onto cabinet - this is easy - and refit plastic clamp
test for leaks on wash cycle as water level is higher
Oct 08, 2008 | Zanussi Washing Machines
How to fix anew door seal on a Zanussi FL1081
turn off atmains
remove the clamp that secures seal to cabinet and peel away the seal.
the seal is held onto the tub by a large spring. at bottom, pull hard down and out and seal will come away.
on new seal, lubricate the slot that goes onto the drum rim with washing up fluid.
start the slot onto the drum rim at the top and work your way round in both directions pressing slot onto rim. this is quite hard work and you may need several attempts.
when slot is on rim all the way round, refit the spring into the outer slot of the seal. this is quite difficult and an extra pair of hands helps
refit seal onto cabinet rim - this is easy and refit outer clamp.
test on rinse cycle for leaks as the water level is higher.
water will foam till the washing up fluid is washed away
note that the seal has a specific way up indicated by an arrow
Sep 07, 2008 | Zanussi Washing Machines
Washing machine
I found 2 websites where you can download your manual, but I did not find any in Dutch. Sorry. Just click on one of the websites and then click on your model number.
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/ZWF1420W-_E
or
http://www.manualsmania.com/brand.php?brand=37&page=5
Please rate this solutiion
Aug 02, 2008 | Zanussi Washing Machines
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
