Question about Intel D101GGC Motherboard
Foxconn MB 66IMXPlus won't boot up
This is a workstation in my office. Computer occassionally stays at the Foxconn screen, won't boot pass it. BIOS could be loaded. Responsive to Ctrl-Alt-Delete. Switched to a different wall outlet location, power bar, different keyboard and mouse, then it booted up to Windows XP. Switched back to old location, boot up was suddenly good. Then next morning (after powering off for 12 hrs), old wall outlet location, boot up was halted at the Foxconn screen again. I was thinking of the following:
1. Unstable power current on the motherboard. The motherboard was only 4 months old. It couldn't be the keyboard or mouse driver since it never boot pass the motherboard screen to Windows XP.
2. RAM starting to act-up. I haven't remove the RAM yet as when I switched wall outlet location, it started to boot to Windows and I couldn't re-create the problem. If there is no problem then there is nothing I could do to test.
3. The power bar is joules protected and is directly plugged into the wall outlet.
4. The workstation was originally placed on the carpet floor and I tried placing a wooden board underneath it to eliminate static.
Is there anyone with any more ideas or have an explanation to this?
What can i do? i lost k8m800-m7a motherboard driver version RV3.01B
Posted on Jan 07, 2009
Bios password for foxconn h61mxe
open up the case and look at the mb, look for cmos reset, you need to turn off the computer use the jumper to short out the board, when the jumper is in place turn the computer on let the system boot up than shut the system down remove the jumper, restart the computer.
if that fails you could try removing the back up battery on the board.
maybe try removing the battery on the motherboard first before resetting the cmos.
Feb 27, 2015 | Foxconn H61MXE-V...
Floppy boot disk
Try setting the boot order in the BIOS to floppy drive first. If that does not work, try writing the floppy again, preferably to a different, new floppy disc in case that one is failing.
Oct 21, 2013 | Foxconn Computers & Internet
Foxconn mobo and Switching power Supply
It could be possible that there are some settings in BIOS that prevent You from booting because as much as the dual PSU is good, it will never give the same electrical current. And when You MB feels the difference, it stops from booting in order to prevent electrical damage.
Oct 01, 2013 | Foxconn Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Foxconn motberboard will not boot disk
Go into the BIOS settings, Usually press the Delete button during the initial boot, and check the settings for the HD setup. Check your MB manual for BIOS access, and correct setup for your hard drive. Possible it's looking for a RAID array and not finding that.Or some similar issue. Also see that the HD is plugged into the correct socket. With SATA sometime, some sockets are ONLY for RAID drives.
May 04, 2012 | Foxconn A88GMV AM3 AMD 880G HDMI Micro ATX...
Foxconn n15235 3 bios beeps
Remove your Ram sticks one at a time and then replace the fried one/s
Apr 21, 2012 | Foxconn Computers & Internet
I HAVE AN ASROCK MB,ALIVE NF6G-VSTA, BIOS PL.50.I STARTED UP.EVERYTHING GOES BUT IT READS ON SCREEN :press F11 for boot menu,and below that it reads:single channel memory mode.IT STAYS THERE and it doesn...
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps you
Oct 28, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
I get a "keyboard not
Are you using a PS2 keyboard or a USB keyboard ? Check your connection, if you are using a PS2 keyboard, plug in a USB keyboard and see if that works
Feb 11, 2011 | Foxconn FlamingBlade LGA 1366 Intel X58...
Intel D101GGC Motherboard Logo
182 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
