Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Shadow lines on screen
My 52" Mitsubishi DLP works great with a hi def input signal but with the DVD player or regular TV signals shows a slightly tilted series of faint lines in the background. Not impossible to live with but annoying.
Any idea what causes it? Could it be an artifact of a weak signal?
Thanks
  • 179 Answers
The DM board is defective. there are approx 20 smd parts that need to be changed. if this board is going then it is just a matter of time before you have the bglod. check out www.tv-techs.com
Posted on Jan 06, 2009
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Toshiba DLP 60" TV not showing TV programs, sound ok
Have the tuner signal board replaced. HDMI does not use the regular tuner bands, it is bypassed when using hd inputs.
Aug 25, 2009 | Toshiba 52HMX94 52" Rear Projection HDTV
Error on screen showing 'unusable signal' - input probs
Make sure you have all the cables in the right places, best to disconnect everything and start from scratch. Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | RCA HD52W58 52" TV
Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No video in any of the TV inputs
first try resetting and rebooting. reset = menu, 2470, enter.
reset is press reset button and wait for green lite to stop blinking.
if that takes care of it great. if not it sounds like a signal board or dm problem and will need repair. check out www.tv-techs.com
Sep 06, 2008 | Mitsubishi WD62628 62" Projection HDTV
DVD's play in black and white
anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from dvd player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Jul 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
