Question about Epson Stylus 2200 InkJet Photo Printer
Epson 2200 going back and forth forever
I have an epson 2200 printer and it just keeps going back to the start position and then starts all over again goes to the end and comes back and starts again and again doing the same thing, I tried resetting it but I am not sure if I am doing it right. It seems to me like the printer does not know where the starting point is to go into the stop mode. Can anyone give me some advice or is the printer shot. Thanks Mike
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
All the lights are blinking and when I tried turning the computer off and then back on, the part that holds all the ink cartridges went back and forth and then went all the way to the left and made an...
unplug printer,access the catridges,remove all the catridges,replug machine in till carrier comes back into normal position,refit catridges propely,try printing
Nov 01, 2013 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus Photo R280 general error The printer has worked fine for years. All of a sudden 'general error' starts coming up. I understand this to be something is jammed in it. When I turn it on...
For Epson Stylus Photo R280 general error You may contact Epson Customer Service for any kind of help you require. You can also call on Epson printer support phone number at +1-800-204-4427 and for UK customers the Toll free Number +44-800-046-5291 we are also provide technical support in AUS Toll free number is +61-1800-954-262.
May 18, 2017 | Epson Stylus Photo R280 Series
After replacement of waste ink pads and cleaning the heads on my epson 2200 head moves fully to right, couple inches left, right again, the full to the left were it strikes the end and then the motor...
Hi Good day!! this error means is you have a mechanical error, maybe the problem is on the gear. i suggest that you contact a local printer technician.. if your printer have warranty use it ^_^
Jan 12, 2011 | Epson Stylus 2200 InkJet Photo Printer
I replaced all the inks with original epson inks **** all the light remians red (2200epson)
Maybe the cartridges are not placed properly! Remove the cartridges and put it back again, making sure they are placed properly, normally you will hear a clicking sound when cartridges are placed properly to position. Good luck!
Jan 11, 2010 | Epson Stylus 2200 InkJet Photo Printer
Can't get printer to work with generic ink cartridges...
I think the problem you're having is that your getting this message on your computer and not the printer.
If that's the case you need to uninstall the status monitor software (leave the driver). This will at least stop the printer telling you how evil you are for depriving Epson of their "rightful" *cough* profits.
If that solves your problem you're away... Epson printers as a rule shouldn't stop you from printing unless there is a genuine incompatibility with the cartridges (ie: you've got R2400 instead of 2200 types) so the status monitor is usually just programmed to annoy you into buying OEM.
Hope that helps but come back if it doesn't with some cartridge numbers for your printer.
Feb 17, 2009 | Epson Stylus 2200 InkJet Photo Printer
Ink jam in Epson 2200 printer
First try to print something. You never know it might work. Also you might try very carefully applying a small amount of sewing machine oil on the bar the print head is attached to then again very carefully and slowly move the head back and forth along the bar. It might just be that the bar is dirty and dry and needs a little bit of lubrication.
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus CX5500 resetting; notification of need for servicing keeps popping up
Hi-
Yep chances are there is a problem with the hardware itself. On the computer where you have it connected directly, did you get an error message? if you did then it talks about part at the end of service life then that is the inkpad you are having a problem with, but if there is no error message that popped up on the computer then there might be a problem on the mainboard, call epson so that they can give you a discount if you are going to buy one from them again. you can reach them at 562-276-4382. Thanks for using Fixya!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Mar 25, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson 2200 printing problem
More a software problem it imaging try reloading the software[driver] and do it exactly as Epson tell you - disable A/N program for example.
Jul 23, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus 2200 InkJet Photo Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
