Question about Fuji FinePix A205 Digital Camera
Camera wont start up
My cam wont start up in video or camera mode it only starts in playback mode if i turn it to video or camera mode it shuts off helppp
    Genius:
  • 2,985 Answers
Go to the Fuji Web site Tech Help. Try another card or if you can access the menu screen format it.
Posted on May 28, 2007
SOURCE:
I can turn my camera on, but there is no screen or sight for recording or play edit.
normally, if you can turn the camera on everything should work including the lcd. if its just an issue with the imaging sensor, you wont see anything on the viewfinder (for the viewfinder to work you need to close the lcd screen) but should at least see the indicators, same in the lcd screen and view your videos in playback mode. if its an lcd screen issue, there would be nothing coming up in any mode the camera is set to. you can try to reset cam back to default settings (press reset while cam is on, its located on the side where you have the handstrap, just below the speaker), or do power reset (remove the batt and ac adapter for at least a minute). if still the same, your unit may require service. thanks. hope this helps.
Jul 21, 2010 | Sony Handycam DCR-HC21 Mini DV Digital...
My sony digital cam wont turn on or remain on. please help me. tell me what i should do
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  7. Attempt to turn on the camera.
  8. Remove the Battery, press the power button for 30 seconds.
  9. Please wait for one minute, insert the Battery and turn it on.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. [[]]
Jun 25, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Video playback is too fast
It sounds like you may be in "Fast Frame Rate" video mode. Turn on the camera to video mode, then press right/left to select normal 640 pixel video. (Depending on the camera model, you may or may not have to press "Func" or "Func Set" first).
Jan 24, 2010 | Canon PowerShot SD1100 IS Digital Camera
How do I transferre my videos onto my pc to record them on dvd
  1. Plug fire wire into computer.
  2. Plug fire wire into Camera. If camera does not have fire wire you will have to use usb cable instead off fire wire.
  3. Turn camera on set to VCR/Playback mode.
  4. Most cameras will be controlled by computer edit / capture software.
  5. Start editing / capture software.
  6. If camera is controlled by computer click to capture footage.
  7. If no control rewind fotage at camera start playback Then pause playback. Start capture in software then release pause on camera.
  8. Wait for end of footage Turn Camera off .
  9. Edit footage.
Feb 16, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Audio in playback mode doesn't work
Hi There, Try this: Connect you camcorder to your tv set via a/v input cable. Put camera in cam mode so you can see the picture on the tv. Turn up the volume on tv and if it squeels, the mic on the cam is ok. Record something and then play it back on the tv, if its ok, then all your audio is functioning. This means that the SPEAKER on your camera is defective.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Camera turns on only in playback mode
davidpl i think there is a problem with the memory card try using a diffrent memory card and it will work fine
Feb 22, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
No picture in rec mode, cam switches off in 10sec
Try using the Dummie Battery and connect that end to charger.
This way you will know that you don't have battery problems.
atdlee@netzero.com
Dec 24, 2007 | Canon XL1S Mini DV Digital Camcorder
After 2 years, erratic behavior.
Lens unit problem. Either imact or sand etc in the lens zooming gearbox area. Maybe uneconomical to repair on this model if new lens unit has to be installed. ( it is shutting off because the lens does not come on line properly and so the shutter and CCD do not come on line... when this happens camera switches off. )
Aug 04, 2007 | Fuji FinePix S3100 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Fuji FinePix A205 Digital Camera Logo
140 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
