Question about HP Compaq ProLiant DL380 G4 Server
I have a HP DL 380 server and its configured as domain controler.... and has a raid5 configration .while we are woking it makes a restart and when its restarted windows was unable to boot asking for NTLDLR file..... then by mistake we restart the sarver while one of the harddisks was removed HD No is 0 (zero). then we but the hard disk back to the server and turn on the server.... and try to repair it by booting from windows server 2003 cd and when we asked to setup windows we found that the D drive becoms as unpartitioned space please help al our data on D and we couldn't access it
  • Rajesh Bhavsar May 11, 2010
    Pls confirm the issue in the same,whether issue in raid or server itself
    Problem Solver:
  • 4 Answers
Are you able to get into the array configuration and make sure the logical drive is still intact? If the logical drive is gone, then your partition may be lost. If you are able to recover the logical drive in your array (which you should be able to if the RAID5 striping was stable) then you should be able to recover your data. You can get into the array configuration during the boot up sequence.
Posted on Feb 06, 2009
Hp dl 380 g5 not noctroller detected via smartstart 8.70
http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=emr_na-c03994176&sp4ts.oid=468780
Nov 01, 2015 | HP Computers & Internet
Hp proliant dl 380 server
How big is your UPS backup. Small home / office only last a few hours before the battery drains. Their role is to allow time to save work and shut properly. Large enterprise UPS's last longer, but are dependent on battery bank size and configuration.
Jul 16, 2012 | HP ProLiant Computers & Internet
I bought Few HP proliant DL 380 G4 servers....they do not have any operating system...i want to install windows server 2000 but it keeps giving me a message " "Setup didnt find any hard drives...
First, make sure all your connections are secure and the BIOS is seeing your hard drives. When you start the install of Server 2000, you will see a prompt at the bottom of the screen saying if you have third party software to install press any key. (or something to that effect.) Press any key and install the needed software drives for the SCSI controller. You will need this to move forward. If you do not have the drivers, you will need to download them to a cd or usb drive to complete your server install.
Good Luck.
C2Solutions
Jul 08, 2011 | HP Compaq ProLiant DL380 G4 Server
I have HP PROLIANT DL 380 (G4). I removed hard disk. Its start and few seconds restart again. its happening continuously. Any solution.
need to provide moreinfo.
is the server (prolaint DL380) constantly rebooting within BIOS mode or has it got to the stage of running windows.
The other item not mentioned here, is, IF the raid controller has failed, you will not see any disks initializing and would cause the system to continually reboot.
If it is an internal raid controller, it is part of the motherboard, you will need to contact HP to have it replaced.
If an pci related array controller .. i.e. separate to the motherboard, this will need to be replaced to see the HDD's.
Either way sounds like a hardware issue. Best to liaise directly with vendor to have the faulty components replaced.
Sep 28, 2010 | HP Compaq ProLiant DL380 G4 Server
My hp DL 380 is hanging and can't restart
Disable the ASR auto-reboot feature from System Management web page. open a case at HP, and run the diagnostic tools from smartstart CD. Kindly let me know.
Jan 26, 2010 | HP Compaq ProLiant DL380 G4 Server
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
DNS Name resolution Between private & Public network.
You do not need to configure ISP's PTR records. Instead define their DNS addresses as forwarders in the properties of DNS server under forwarders tab and flush DNS cache.
Mar 24, 2009 | Microsoft Computers & Internet
Problem with DL380 G4 after reboot
do you use software/hardware raid?
hopefully hardware :-)
and is it mirrord or raid5?
Jan 26, 2008 | HP Compaq ProLiant DL380 G4 Server
Boot problem with a ProLiant DL 380 server,
To enter the BIOS of a ProLiant DL380 you have to press "F9"
Jan 23, 2008 | HP Compaq ProLiant DL380 G4 Server
HP Compaq ProLiant DL380 G4 Server Logo
218 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
