Question about MSI G33M-FI Core 2 Quad/ Intel G33/ FSB1333/ DDR2-800/ IEEE1394/ A&V&GbE/ MATX Motherboard
MSI G33M Board won't post when I switch from stock RAM to Corsair TWIN2X2048-6400CDHX, is bios re-flash necessary?
  • 53 Answers
Samuel_mcnam,
It was tested that your motherboard should be able to support the ram, check out the report here,
http://global.msi.com.tw/uploads/test_report/TR10_1184.pdf
Then again, I recommend you to try with different RAM slot available on the motherboard,
worst come to worst, no hard to try to update to the latest BIOS firmware date 2008-07-08.
http://download2.msi.com.tw/files/downloads/bos_exe/7357v13.zip
Good luck, don't forget to rank my solution, thanks.
Posted on Jan 12, 2009
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
The operating system is not install.. the problem is"bios is not install press "g"but i can't under"
There is a jumper setting on the board that resets BIOS if necessary. If BIOS is not present you will have to flash the board to get a working BIOS.
Jan 12, 2011 | MSI K9MM-V Motherboard
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
Sir I want to ask that what is the best Board for Intel Core 2 Due (E7200)?
i use the same cpu with a msi g33m board. u too may use it but u should ve at least 2 gb of ram and at a 9 series gpu.
Mar 03, 2009 | Computers & Internet
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Upgrade for mbd ms-7357
Click here for live update page for auto recognition of your motherboard to inform of bios and driver updates
Sep 09, 2008 | MSI G33M-FI Core 2 Quad/ Intel G33/...
Msi p35 neo2
take off all the stuff from the mobo except the processor, a stick of ram and the graphics card - will it get further now?
Jul 02, 2008 | Intel Motherboard
Only fans are starting - nothing else
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Feb 08, 2008 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
MSI G33M-FI Core 2 Quad/ Intel G33/ FSB1333/ DDR2-800/ IEEE1394/ A&V&GbE/ MATX Motherboard Logo
197 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
