Question about Refrigerators
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
    Scholar:
  • 160 Answers
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jan 06, 2009
Ice but no water after filter change.
There may be a delay in the water dispenser flow after filter change due to air in the system but if you still have problems we will need to check the water control valve. What is the model number of your fridge?
APPLIANCE 911
Nov 28, 2015 | Refrigerators
Electrolux Pure advantage water filter
Open and shut the water valve quickly to verify the water supply, it could be a bad water supply valve. Bench test the filters for flow or obstruction.
Aug 01, 2017 | Electrolux Icon Freezers
Water dispenser and ice maker are not working, water supply to refrigerator is ok.
Check / replace the filter. Many fridges have a filter readily accessible from the fresh food compartment. The filter should be changed at regular intervals for best performance. A filter that is never changed will reduce and eventually stop water flow through it.
Check the temperature of the fresh food compartment near the filter. It may be "flirting" with the 32 degree mark. If it is this low, water has turned to ice - and will stop water from flowing. Bump the temperature up a tad to see if it solves the problem.
Lastly, the water supply solenoid may have failed. You didn't provide the model fridge - so I can't give specific info about it - but many fridges have one or two solenoids at the rear of the fridge for water supply and ice makers. You should hear a clicking sound from the rear of the fridge on many models when dispensing water or when the ice maker cycles on. If one has failed, you may expect to pay about $15 to $50 for a replacement - depending model.
Typical GE Refrigerator Single Solenoid Water Inlet Valve "WR57X10033"
Solenoid valve replacement is pretty straight forward. Usually all the is needed are some simple hand tools and a rag to pick up spilled water. Make sure the water supply is shut off and unplug the fridge before attempting.
If my answer was helpful - please rate it. Thanks & good luck!
Oct 05, 2011 | GE Refrigerators
I installed a new fridge filter and now my ice maker will not make ice.
Check the direction of the water flow for the filter, did you put it on backwards? Did you open the pep-**** to allow water to flow to the unit again? Did the ice-maker line freeze up when you were changing the filter. These are all things that are common mistakes when changing the filter. Check this things out and get back to me with an update...
Jun 14, 2011 | Microwave Ovens
Ice maker stopped working
The water line may be clogged with debris. there is sometimes a filter in the water line to the fridge, or also a screen filter may be located at the point where the water line connects to the fridge. If they are clogged, your ice maker will not make ice and may even burn out.
Check that the water in the line is flowing freely. Also it might be a good idea to defrost the freezer in case you have a ice buildup in the freezer compartment. To do that, empty the freezer and blow air into the freezer for 30 minutes while the power if off. Note, keep the other side closed to protect the milk and other perishables.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a Jenn Air, french door style, bottom freezer. with the water dispenser on the inside left jamb of the box. there is also a ice maker. for the first 9 months every thing worked very well. then...
You have another plugged filter. That is why you ice cubes are hollow, the water is flowing so slowly into the ice maker, it does not fill up.
Recommend you install an external filter somewhere in the feeder line that connects to the rear of the refrigerator. The are surprisingly inexpensive, compared to the filter inside the new 'fridges. I recommend you buy a replacement external filter cartridge at the same time you buy the external filter kit. Of course you will need to change the internal filter one more time or bypass it per any instructions provided with your fridge.
Aug 11, 2009 | Refrigerators
No water flow to Ice Maker or water dispenser
There is a filter in the back of the fridge in the upper right hand side. If you do not change it, it will slow down the flow of the water causing it to freeze at the dispensing part in the ice maker. Look at the ice maker from the side and you can see the little plastic piece where the water comes down. Reach up and feel to see if there is ice caked inside that piece. If there is you most likely need to change the filter and defrost the freezer. If something else is the problem I can't help you there, lol... this is just from my personal experience.
Mar 21, 2009 | KitchenAid Refrigerators
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Cant get water out of the fridge door
hello allamericananp,
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
412 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
