Question about HP DeskJet 970cxi InkJet Printer
Reset button constantly flashing and wont reset!
Printer made a noise and then.....Reset button constantly flashing. No paper jams etc. When reset button is pressed the power light briefly flashes green and then goes off, just leaving the reset button still flashing.
cressy
  • 5 more comments
  • cc1 Jan 08, 2009
    Thanks Riztech; reset button has stopped flashing but is now on constantly and wont go off when pressed. Cartridges at LHS and when switching on/off they clunk but don't prime etc. Is this a gonner?
  • cc1 Jan 09, 2009
    Cartrigde can be mannually moved
  • cc1 Jan 09, 2009
  • gr8whtnorth Jan 16, 2009
    My daughter just called with the same problem! The light flashes or is solid red, and the ink cartridges don't move when the lid is lifted. She's afraid to move the belt for the cartridges though, so I don't know if it is 'stuck' or not.
    MAK
    Identical problem! Cartridges don't move when lid is lifted.
  • rjmorin01 Feb 09, 2009
    stuck I tried unplugging the power cable- no results
  • ladybugterp Mar 08, 2009
    The button that shows paper with arrow blinks red as well as the power light blinking green. If i press the red lighted button, the cartridge moves to one side and the machines "growles". Then the cartridge goes to the other side. The buttons continue to blink. Paper doesn't feed through. I've unplugged the unit and it continues to blink once plugged back in.
    Tiffany
    Guru:
  • 731 Answers
Hi Cressy
1.Power off the printer, then Unplug the power cable from back of printer and from wall outlet.
2.Press and hold ON button for 30 seconds
3.Now plugin and check the printer
Thanks
Riz
Posted on Jan 07, 2009
  • Mohammed Rizwan
    Mohammed Rizwan Jan 08, 2009
    Cressy,
    Are u able to move the carriage that holds the ink Cartridge? or its stuck??
Printer wont start error flashes, M @ K colour flashes clear button wont work
Usually the errors are related with the cartridges being empty or having another issue ..or a paper jam is detected..So check it for paper jam ..than check the cartridges..(if you didnt used it in a long time ..they may be dry ..and this model do not support well refilled so need to be changed) ..after checking all that ..try to reset the printer ... Im not sure about the procedure ..but try first to power reset it ..While it is on ...remove the power cable and after a few minutes..insert it back ..than press the power button and keep it pressed for 15 seconds..and see whats going on ..On the net I didnt found a reset procedure ..but it may be available if you consult the support site..
Aug 08, 2011 | Konica Minolta Magicolor 1600W Printer
When I turn on my epson nx110 a loud constant, buzzing noise comes from my printer. I have found that is based in the part that lifts up not the base of the printer. In addition the on/off button is...
you may need to software reset you epson printer, some epson printer has a print counter, once you have used your allowable print, it goes into errors mode, flashing the on/off button light..check also for jamb paper inside..
Feb 09, 2011 | Office Equipment & Supplies
Got paper jammed pulled it out but now won't work tries but then red flashing and makes a bit of noise
-To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
-For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
-Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
Oct 02, 2010 | Epson Stylus Photo R220 InkJet Printer
I have a HP laserjet P2015dn Printer, i have no idea what is wrong with it, the paper jam light is constantly on when I turn the machine on, the light is not flashing it is constant, ths is not covered in...
Make sure you check the paper path thoroughly. Even a small piece of paper can obstruct a sensor and keep it from moving. Be sure to open the rear door and check the fuser sensor as well. If you still cannot find any obstruction or stuck sensor(s), perform a cold reset as follows:
  1. Turn off the printer.
  2. Press and hold the Go button.
  3. Turn the printer on, and continue to hold the Go button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED turns on.
  4. Release the Go button.
If both the Attention and the Ready LEDs turn on before you release the Go button, you must start the procedure again with step 1. The printer’s LEDs begin cycling. The cold-reset process runs until completion, and the printer returns to the ready state.
May 01, 2010 | HP LaserJet P2015dn Printer
Printer 1270 front control panel lights are flashing constantly and the printer wont move or react to any manual inputs
Turn the printer off.
Press down the ink button and the paper button at the same time and turn the printer on (while keeping them pressed down)
After a second or two, the red paper light should start flashing.
Immediately release the buttons and press and hold the paper button again. Keep the paper button down for about ten seconds and release. After a second or two, the printer should go back to it's normal state.
Please try this and reply me for further doubts.
Regards, Nandini.
Sep 14, 2009 | Epson Stylus Photo 1270 InkJet Printer
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Jun 09, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Paper jam that isn't
You could try a partial reset of the printer
Unplug the power cord
Reconnect power cord
When lights are flashing, press & hold On/Resume and PaperSize buttons
When only the On/Resume light is flashing, release both buttons
When On/Resume light is steady, reset is completed
Feb 21, 2009 | HP PSC 1210 All-In-One InkJet Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma iP1600 Printer problem
sure..disconnect printer from computer and then try a test page from printer stand alone
Aug 19, 2008 | Canon PIXMA iP1600 Printer
Printer
One of two things.
1. When the jam occured there may have been a small piece of paper torn off on a sensor.
2. And I think this is more likley. One of the sensor actuators has fallen off or is stuck causing the sensor to think there is still paper in the machine.
Take your time and examine the paper path carefully.
The actuators are black plastic pieces about an inch long hanging down into the paper path.
Jan 11, 2008 | Brother HL-2040 Laser Printer
HP DeskJet 970cxi InkJet Printer Logo
1,335 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
