Question about Brother MFC-9420CN All-In-One Laser Printer
Toner Cartridge empty
My new toner cartridge says it's empty. This is the second new cartridge I've put in and I get the same message.
    Genius:
  • 1,605 Answers
Does the display come up as "toner empty x"? what is the last character after the toner empty ?
where x is:
c=cyan= 6,600 pages
m=magenta=6,600 pages
y=yellow=6,600 pages
k=black=10,000 pages
Posted on Jan 06, 2009
My Sharp Ar-M155 is displaying d message replace the toner cartridge. I ve tested d cartridge with another machine and it is working perfectly
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 07, 2011 | Sharp Office Equipment & Supplies
Where is the toner sensor on the toner holder in the DCP-7020 it keeps telling me toner is empty and toner should not be empty yet.
If you look at your toner cartridge you should be able to see a clear plastic circle. That's part of the toner level mechanism. I've gotten a few more prints out of my cartridges by putting a piece of tape over the clear plastic and coloring it black with a sharpie. However, there are other mechanisms used to gauge toner levels, and this will not be a permanent fix.
I've also gotten a little more life out of it by simply shaking the toner cartridge for about 15 minutes. It helps coat the inside and might break up chunks inside the cartridge itself.
Jun 16, 2011 | Brother DCP-7020 All-In-One Laser Printer
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Toner empty message after replacing the toner Ricoh fax2210L
menu # 1934 menu search for new cartridge and then click yes yes ,turn power off and on.
Jun 18, 2009 | Ricoh FAX2210L Plain Paper Laser
Error message says toner cartridge empty, but it is not empty
I am not certain this procedure will work with your model, but it's worth a try:
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100\%.
Jan 03, 2018 | OKIDATA - 91615001 Printer
I don't know how to remove and install toner for my sharp ar-337
If you go here:
http://www.sharpusa.com/files/cop_man_ar287_337_407.pdf
You can download the operation manual for that machine, on page 4-5 they explain how to replace the toner and have pictures showing how.
here is the text on how to replace.
Adding Toner
1 Open the front cover.
2 Pull down the toner hopper lock lever and pull the toner
hopper out slowly until it stops.
3 Tap on the top of the toner cartridge 5 times. Hold the
new toner cartridge vertically and vigorously shake it
up and down about 20 times, then invert the cartridge
and again shake it up and down about 20 times. This will
loosen the toner and allow it to flow more easily into the
toner hopper.
4 Place the new toner cartridge with the tabs in the
notches as shown.
5 Slide the toner cartridge along the guides over the toner
hopper.
6 Hold the toner cartridge with one hand while pulling on
the sealing tape to remove it.
7 Tap on the top of the toner cartridge 5 times to start the
flow of toner into the toner hopper.
l If the toner cartridge was sufficiently shaken as described in step
3, it will take about 50 seconds for the cartridge to empty. Do not
remove the cartridge until it is empty. If not empty, tap on the top
of the cartridge again until empty.
8 Slide the empty toner cartridge back along the guides
and remove it.
l The cartridge opening will be closed as it is moved back along
the guides.
9 Slide the toner hopper into the copier and return the
toner hopper lock lever into place.
10 Close the front cover.
NOTE:
Add only one cartridge of toner.
Jun 19, 2008 | Sharp Office Equipment & Supplies
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
"toner empty" problem
The samsung sf 5100 toner cartridge has a .05 Amps fuse in it. This gets blowed when you switch on the machine.This is used to reset the page counter and also to inform the machine that you have inserted a new toner. Now this recycled cartriges will not have this fuse and this is the reason why your machine shows TONER EMTY message! If you dont get the same rating fuse, put any fuse of the same size, insert the toner, close the door and just switch on the power and switch off immediately. Then take out the Toner cartridge and remove the fuse. Now your cartridge is ready for use.
Dec 06, 2007 | Samsung SF-5100 Plain Paper Laser Fax
False Toner message
Are you using genuine HP toners? If not HP puts a chip on there cartridges that tells the machine it is a new cartridge. Some generic toners do not replace this chip therefor giving you this false message.
Jun 21, 2007 | HP LaserJet 4600dn Color Printer
Brother MFC-9420CN All-In-One Laser Printer Logo
580 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
