Since I installed my Powerstar AE115 in Oct. I have seen my electric bill double each month. I have tested to make sure connections were correct and tight. I have turned off the breakers one at a time and checked the meter, and it seems that if I keep #1 breaker on and turn off #2 there is no change and I still get hot water. However, if I turn on #2 breaker and and turn off #1 breaker the meter stops spinning so fast , but with no hot water delivery.
Should both tanks heat up water at the same time? How does that work?
And what might be my solution's?
Hi Is this powerstar AE115 a tankless water heater? I suspect the 115 designator in the model number means it runs on 115 volts. And what is the second Tank ? Storage or an electric water heater? Both should be rapped with insulation to hold the heat. Meaning storage or electric water. Don't rap a tankless water heater. At the very least get a licensed electricen in to make sure you electrical service will support a 240 volt system. If it can , do it. Think of electricity as a river flowing. Volts are the speed the water flows. Amps are the force ( Also caled Impedeance) that push the water.( And spin your meter like a top I might add.) And resistance as how many bolders, Rocks, Old fords that are in the river bed slowing down the flow of water.Now here is where OMES LAW comes in. E= I x R. (E) volts is equel to the (I) impedeance (Amps) multiplied by the ( R) resistance. You can spin this in a clockwise direction and find the net value by dividing one from the other to get the net. ( I = R * E ) If This is true ( and it is ) if we double the voltage (current) we can realise a reduction on the Impedeance (Amps) of up to 1/2 of its current value.In other words if you were useing 100 amps @115v you will use 50 amps @240v Depending on the resistance. Sorry but I forget the voltage drop on 100 feet of copper wire but I assure you its real low.But your best bet would be to use a tankless water heater core in you boiler that you use for heat if you got one and save the electric for summer mode.
