Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Reset Time Problem on Panasonic TV (PT-50LC13)
I have Panasonic TV. Just recieved brand new bulb (PT-50LC13) and replaced it carefully. Tryed to turn on the TV and the power light turns green and flashes slowly a few times, then faster for about 1 minute or so and turns red. No picture at all. And as far as re-setting the hour meter. I should have a video picture to do the re-set right? Thanks for any help!
  • Anonymous Feb 18, 2009
    i put a new lamp in and know it tells me to reset the hour meter
  • Anonymous Mar 30, 2009
    I had the exact same problem and had a repairman come out - It was the ballast that had to be replaced, for aroud $500.
  • 108 Answers
Power on the set, listen for afaint buzzing sound as the set tries to fire up. If you do not here it then your lamp driver, or ballast is most likely faulty. Also make sure you have the door and all covers back in place and secure. And make sure you insatlled an orginal panasonic lamp because some generic will not work.
Posted on Jan 09, 2009
Panasonic PT-50LC13 50 blinks 8 times at power button
hi, make sure the lamp is fitted securely and the lamp cover as well you may need to reset the lamp counter hope it helps
Nov 27, 2011 | Panasonic PT-50LC13 50" Rear Projection...
We have a Panasonic PT-50LC13, the buld died and the unit would no longer light up. We replaced the bulb as noted and the unit still won't light. Do we need to reset something so the unit recognizes a new...
hi I just read that this tv needs a few minutes to warm up i am going to .try it. iam having same problem. i had a tv tech install a bulb and it worked .
but i had a dispute with the tech about the cost of the fix and he took out his bulb and all though i purchased a new housing with bulb in it so that i didn,t have to touch the bulb, when i put it in i got nothing but green to flashing red to yellow. so if my bulb is good and the tech didn't
do something malicous than something has to be reset so that the tv will work because not even the sound of the tv worked.
if you get the ansewr to this please email to
Oct 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
SPLIT for Models:
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 Power Light Blinking Yellow
My Panasonic PT-50LC13 when turned on has a green light for a few seconds you can hear the fans turn on and then you have a yellow/amber light that starts to blink 8 times i have replaced the bulb and the door is closed any ideas?
Apr 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic model# PT-50LC13
It very well could be the ballast. I unfortunately have this tv and keep extra bulbs because they go out about once a year. Last time when I replaced the bulb the tv blinked and the red lamp light flashed like it does when the bulb is bad. Ballast repair kit fixed it up. This is certainly a design issue but you'll get no help from Panasonic. If tv comes on the goes out after a while, clean the fan filter.
Feb 17, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Have panasonic pt -50lc13 tv
Hold down vol - on tv and hit either PIP or SPLIT on remote
Jan 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13 shutting off
i'm on my 3rd bulb in 5 yrs. i hate this tv. this time my bulb light didn't come on. instead the power light flashed green fast then went to red flashing after. i took out the bulb and it's blown!
Nov 19, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
780 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
